Vibrating when braking ****PLEASE HELP****
Old Sep 24, 2009 | 04:00 PM
Dark_'s Avatar
If you get a vibration while cruising it's likely bad tires/bent wheel(s)/worn suspension.
If you get a vibration only while accelerating it's likely worn CV axles or a worn driveshaft.
If you get a vibration while braking it's likely warped rotors.
OP, you say you replaced the front rotors but the vibration is coming from the rear...obviously you should suspect the rear rotors unless ALL 4 were warped from the beginning.
Old Sep 24, 2009 | 04:02 PM
Dark_'s Avatar
Originally Posted by 4Dr.Madness.
hmm i see, but the owner told me he never had any problems with them. No vibratiosn at all?
He could be lying or they weren't packaged/shipped properly.
Did you remove any oils from them before they were installed?
Were you a little easy on the brakes for awhile so that the pads and rotors would 'bed'?
Old Sep 24, 2009 | 04:03 PM
4drmadness's Avatar
nah it was a homie who i picked it from. Hmm dint really bed in actually. thought they were used so dint have to.
Old Sep 24, 2009 | 04:08 PM
Dark_'s Avatar
Unless you were using the exact same pads he was using(not just the same brand/model) and installed in the same orientation as he had them then yes, you would need to re-bed the rotors and pads.
You do know what it means to 'bed' the rotors and pads, right?
Old Sep 24, 2009 | 04:09 PM
4drmadness's Avatar
yes i basically took his calipers, pads, rotors, and ss lines and put them on my car.
Old Sep 24, 2009 | 04:13 PM
Dark_'s Avatar
If that's the case then you/he may have accidentally got brake fluid on the pads and/or rotors during the removal/installation. This is simply from the assumption that they were not warped before he removed them from his car.
Old Sep 24, 2009 | 04:15 PM
4drmadness's Avatar
hmm that mite be the case. wats the solution?
Old Sep 24, 2009 | 04:19 PM
Dark_'s Avatar
If they are already warped then you can measure the thickness to make sure they are still within spec, if they are you can get them machined. Once they are machined you can reinstall them and you should be good to go.
If you want to play it safe you can have the same place machining the rotors grind down some of the pads for you in case they are contaminated (cheaper solution over buying new pads).
After either step you'll need to re-bed the rotors/pads.
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Sep 24, 2009 | 04:20 PM
4drmadness's Avatar
^ thanks a lot for your help!
Old Sep 24, 2009 | 04:22 PM
Dark_'s Avatar
np and good luck! Stoptech rotors aren't cheap but if they don't have a ton of miles on them then you should have plenty of 'meat' left for machining. If they weren't Stoptech then I'd probably say buy a new set.
Old Sep 24, 2009 | 04:24 PM
4drmadness's Avatar
yea lol! im gona go to my mechanic in an hour or 2.
Old Sep 25, 2009 | 06:51 PM
Dark_'s Avatar
Any luck getting it fixed?
Old Sep 25, 2009 | 07:02 PM
4drmadness's Avatar
yup got it fixed. weirdest solution ever!!!
Basically my coilovers were put on too tight causing vibrations!! Brakes were fine
Old Sep 25, 2009 | 07:03 PM
Dark_'s Avatar
two birds with one stone, kind of!
awesome, saves all the hassle of grinding down the brakes.
Old Sep 25, 2009 | 07:04 PM
  #30
4drmadness's Avatar
yup!!! Was soo happy lol
