Ac/radio control unit
Old Oct 1, 2009 | 02:30 AM
docbong88's Avatar
Thanks, but the problem is in the radio. So if i pull the fuse, the default will be set and it will still turn on automatically when my radio dash dies, EVEN though i pulled the fuse?
Old Oct 1, 2009 | 11:46 AM
NFSP G35's Avatar
? = 2B || !2B
If I remember right, it does turn on automatically in some stupid default setting because the ac unit can't read the controls because they're on the same board with the radio.
Old Oct 1, 2009 | 12:00 PM
KDmospd's Avatar
Common problem on 03-04. You need to replace the headunit.
DO NOT RELACE THE HEAD UNIT. Do this first -
Link - https://g35driver.com/forums/g35-sed...grees-fix.html
HERE IS THE FIX - check fuse # 15 that’s in the area by the battery, UNDER THE HOOD...
Old Oct 1, 2009 | 12:06 PM
KDmospd's Avatar
Originally Posted by docbong88
I know... I'm doing research into what HU i'm going to buy, but int he meantime the FULL blast AC is pissing me off and i want to pull the fuse for the a/c. Just wondering if this will mess anything up and where the correct fuse to pull is located.
No, This happened to me on memorial day weekend and I changed the fuse in the fuse box by the battery, haven't hand any problems sense...
Old Oct 2, 2009 | 03:43 AM
DRE073's Avatar
I spoke to my mechanic and he said that the 03 sedan's don't come standard with the navigation hub which is why the screen doesn't turn on. I'm going have a DVD wired to the screen so it has a purpose. Thanks for all the help!
Old Oct 5, 2009 | 07:31 PM
joedaddy1's Avatar
lol what? i have a 03 sedan and I replaced the cd player myself and my NAV still works fine.. what's your mechanic talking about? if i RECALL correctly, there's a plug that goes in from the NAV to the headunit.. this probably mutes it..
i am pretty sure he didn't push in all the plugs correctly.. your NAV was working before right? i dont see a reason for it to STOP working...
Freeman186
Sep 6, 2023 10:07 AM
JustinMKN1
Sep 18, 2015 03:40 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
