easiest way to run a power wire??
Old Oct 1, 2009 | 03:57 PM
midnytegsedan's Avatar
whats up?? does anyone knowthe easiest way that i can run my power wire running from the battery to the amp in my trunk? i've been looking on the firewall in on the passenger and driver's side of the car and i can't seem to find an easy path, PLEASE HELP!
Old Oct 1, 2009 | 05:29 PM
6MTFTW's Avatar
There's a place behind the battery that goes down through next to your ECU. I've always used that one. Just pull the entire battery cover and you'll see it.
Old Oct 1, 2009 | 05:38 PM
G35pwrd's Avatar
Yep, what 6MTFTW said. Hood open, pop battery cover, pop battery cover holder. See a HUGE 3 inch/4inch diameter rubber grommet. Take a flat head and poke a hole in it, then force feed wire in. Get flashlight, look under dash and pull to yah. If you don't see it at first, push more wire in, twisting it as you do. Should end up at the passenger kick panel.
Old Oct 1, 2009 | 07:26 PM
saoLin413's Avatar
Check out this DIY. Exactly where I ran my power wire.
https://g35driver.com/forums/audio-v...se-system.html
Old Oct 2, 2009 | 10:17 AM
ttrank's Avatar
Grocery getter
+2 on what 6MTFTW said.
Danielek
Aug 11, 2015 09:33 AM
Thunderaan
Jul 22, 2015 07:40 PM
