MODE HVAC Button - Rant/Question
Old Oct 16, 2009 | 12:29 PM
G35fromTO's Avatar
Got a question about how the "Mode" button is supposed to work. Right now when I press it, it will go in a sequence something like bottom vents, top vents, both vents, and window and bottom vents... after this if I continue to press the Mode button it repeats the same options but also turns on the A/C. I find that retarded and I'm just wondering if EVERYONE has that or if I'm doing something wrong? I'd like it to just go in a cycle without turning on the AC. If the A/C part is how it's supposed to work then all I got to say is the people at Infiniti are RETARDED! Seriously.... it's pretty normal that when I have the car on a warm temperature that I would want to switch between bottom and top vents a few times as I'm driving and I do not need the AC!
The other part is that the owners manual is quite crappy! I'm not a big fan of reading owner manuals but this is one case where I tried to refer to it and this isn't covered at all in it. Neither is the part on how the vents will switch as you change the temperature, something that has caused questions from a lot of people on here.
TIA!
Old Oct 16, 2009 | 12:33 PM
4DGS's Avatar
Mine doesn't do that, I can scroll through mode all I want. I have to manually turn on my A/C.
Old Oct 16, 2009 | 12:37 PM
G35fromTO's Avatar
Now I got a mystery on my hands!
Old Oct 16, 2009 | 12:44 PM
semicycler's Avatar
AC turns one whenever the front defroster is selected by the mode switch. Kind of silly when it's winter in MN and -20 degress outside!
Old Oct 16, 2009 | 08:41 PM
6MTFTW's Avatar
Air conditioning doesn't mean making it colder. Moisture is also taken out of the air. That's why, when the defrosters are selected, it automatically turns on the A/C compressor. That way it dries the air before it gets to the windshield.
Old Oct 16, 2009 | 10:45 PM
G35fromTO's Avatar
Yep, that's what happens with mine but it doesn't turn off as you continue pressing the mode button and the air vents are changed back to the none defrost ones. Would make sense if it did.
Old Oct 16, 2009 | 11:21 PM
Tollboothwilley's Avatar
Probably normal. 03/04 have issues with HVAC and stereo operations with the stock dash piece though.
Old Oct 17, 2009 | 10:56 AM
blazeplacid's Avatar
whats your temp set at when you running though the mode options?
Old Oct 17, 2009 | 12:20 PM
G35fromTO's Avatar
Yesterday when I was checking this again, I had the temp at 26 celsius or 78.8 fahrenheit.
Old Oct 17, 2009 | 12:23 PM
STCLAIRWEST's Avatar
Mine does this once it hits defrost so it shoud be normal
Old Oct 19, 2009 | 11:28 PM
NFSP G35's Avatar
? = 2B || !2B
Mine doesn't do that. Must be an 03.0 vs 03.5 thing
Old Oct 20, 2009 | 10:13 AM
G35fromTO's Avatar
Mine was purchased by the first owner in June of 2003, so I don't know if that would make it 03.5 or not.
If they stopped doing that on the later releases then I guess they realized how STUPID the design was! There are times when I will switch the vent mode and not catch that the A/C went on until I hear it or something...
And again, that owners manual is CRAP! Little details like this should be covered instead of having the owner guessing.
Oh well, just something I have to live with. Still love the car
Old Oct 20, 2009 | 10:45 AM
NFSP G35's Avatar
? = 2B || !2B
Your sig says 2003.5 and you don't know if it is??? It's easy to tell the differance, doggy-door/no doggy-door.
Old Oct 20, 2009 | 10:57 AM
G35fromTO's Avatar
Yeah... that's why I put 03.5, you just reminded me...
Also, I got manual, and doggy door version only came with auto if I'm not mistaking...
Old Oct 20, 2009 | 10:58 AM
Canuck's Avatar
Yes the A/C goes on when you cycle through and it hits defrost. No it doesn't turn back off when you cycle through the rest of the options. It is like that in my 2006.
I really don't understand what everyone has the problem with. To reiterate: having the air conditioning on in the winter does not cause the system to blow cold air. It simply removes the moisture from the air so that your windows don't fog up.
If this "glitch" bugs you so much, save yourself the hassle and just put your climate control on auto.
