need help...vibration...
Old Aug 16, 2004 | 02:02 PM
hotGspot's Avatar
After I put my 18" Cypher couple of mos ago, my steering wheel vibrates at 60 mph. I read about the hubcentric rings, and just recently installed them on my wheels. I did balancing the wheels and all, but the vibration still there. What should I do?
Thanks,
Buche
Nothing Turns You On More Than The "hotGspot"
Old Aug 16, 2004 | 02:25 PM
BLICX13's Avatar
Re: need help...vibration...
It's either those hub rings or balance or a bent wheel - if your set up is not staggard - then move the backs to the front - see if the vibration goes away - but any vibration between 55 - 65 mph like you are explaining is usually a balance issue... good luck
Old Aug 16, 2004 | 03:14 PM
IQ9's Avatar
IQ9
Have you had your alignment checked as well?
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
Old Aug 16, 2004 | 06:58 PM
ABQ_G35's Avatar
How bad a vibration are you talking about here? Is it on all roads?
Brilliant Silver/Graphite/Chrome Wheels '04 Sedan/5AT
Old Aug 17, 2004 | 07:25 AM
hotGspot's Avatar
sometimes it comes and goes....I do not think its an allignment problem...cuz my car is going straight on the smooth road...
Old Aug 17, 2004 | 10:11 AM
Q45tech's Avatar
Members don't realize or even test the new wheels they buy to see if they meet oem minimum runout specs.
Probably half or more of inexpensive [non full forged] don't meet spec brand new.
Hub centric rings are another nighmare.
Old Aug 17, 2004 | 12:03 PM
ABQ_G35's Avatar
I have always noticed certain places in the road where I get a tad of steering wheel vibration, on most cars I have had, so sometimes it is the road, even though it appears nice and smooth, we have a spot here, a relatively new stretch of interstate where I notice some, but my last car also did it there, so I know it's not my G.
Old Aug 17, 2004 | 12:42 PM
hotGspot's Avatar
So...in other words, I got f**ked with these wheels?...anything else that I can do?...
I drove my wife max..to find out if it is the road. My wife max doesn't vibrate like my G.
Old Aug 17, 2004 | 01:11 PM
Q45tech's Avatar
Don't know but you'll never know till you test each wheel on a Hunter 9700 without the tires.
Old Aug 17, 2004 | 02:27 PM
hotGspot's Avatar
thanks for the inputs...do you know how much it costs to balance the wheels without the tires?..
Old Aug 17, 2004 | 06:35 PM
Q45tech's Avatar
Obviously you have to pay to demount, then balance on Hunter 9700 [which is more expensive to pay for the longer time and more expensive machine] then fix the wheels, then remount the tires then balance the total assembly.
Probably $40 to $200 per wheel [if you have to repair the wheel].
Don't understand why members don't check wheels before the tires are first mounted.......draw a picture of EACH wheel [number each wheel inside] and reference imbalance from valve stem hole [inside and out].
That way when you change tires you can check the wheels each time..........quick and dirty [less expensive on a srtandard balancer] in 3 minutes each.
Precision and perfect vibration free isn't cheap - most won't spend the money or time.
I always point out that tire and wheel maintainence can cost more than the tires..........even $250 ones.
A standard radial force balance on a Hunter 9700 is roughly $25 in Atlanta plus some additional amount if the tire must be rotated on rim to minimize radial forces.
Wheel repair is $140-$200 each plus some extra to achieve oem spec for runout.........not really worth it unless the wheel is forged as cast [many/most] won't stay round.
