Another one of those "im getting a weird noise" threads...
Old Nov 13, 2009 | 01:57 AM
G35xChicago's Avatar
Getting weird knocking/clicking noise.
- Only when i am starting to move/turn and when i hit brakes under 5mph or so
- Seems to be coming from driver side towards the outside of the car and more "high up" as opposed to from below.
-Noise doesnt sound like anything crucial, just sounds like something might need to be oiled???
My assumption: Coilovers??
Old Nov 13, 2009 | 05:50 PM
bbs350z's Avatar
could be anything. beware, it could be your compression rods. those tend to go out lol
Old Nov 14, 2009 | 12:16 PM
TurTLe*'s Avatar
sounds like the normal compression rods. but its really ANYTHING and EVERYTHING in that area. here are some common issues.
compression rod noises are more caused by uneven roads, liking pulling in and out of drive ways and alleys. I have that noise on my car from time to time. Going to replace the bushings in the summer.
you also have SPC arms so it might have something to do with that.
And then the always typical swaybar endlinks/ bushing.
Old Nov 14, 2009 | 12:39 PM
Tollboothwilley's Avatar
Do you have aftermarket sways and endlinks? If so, use some white lithium grease on the endlink swivel ends.
Old Nov 14, 2009 | 01:53 PM
Based on doing some more research on here and calling a few dealerships, it most likely is the compression rod bushing on the driver side, a $20 part but $160 to install because you need a hydraulic press to get the bushing out of the compression rod assy.
I do have the spc A arms, but dont have any aftermarket sways. Wonder if it would be beneficial to grease some of the joints in the area as a whole.
Old Nov 14, 2009 | 02:14 PM
TurTLe*'s Avatar
i know the compression rod bushing is like $20-25 and i know they have an updated one that suppose to last longer but i'm wondering if there is a aftermarket bushing for that. maybe from moog or energy suspension. that is what i would look into first and foremost because it seem as if most rod bushings go 30-50k on here.
06g35
Feb 14, 2022 05:59 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
reaper76
Sep 20, 2015 11:59 AM
Albanian122
Sep 12, 2015 04:02 PM
