Radio Fading Need Help
Old Nov 17, 2009 | 03:31 PM
fzr's Avatar
fzr
I Posted this in the Audio forum but didn't get anywhere with it...
Hey guys after installing my Kenwood 7100 deck, I noticed while driving only the Radio on each station fades in and out, I didn't have this problem before with the stock deck but with the kenwood + the antenna adapter(which I needed to connect the factory antenna car connection to this deck) I get this problem...
Any suggestion, I really don't want to take out the deck again but I might have to change the Antenna conversion that runs from the car to the deck, which I had to use when installing this deck...
Any input would help this fading is driving me NUTS...
I installed the deck for the navi, I sometimes get bored and listen to the weather and news...I think it is the link/extension for the antenna because everything else works fine...No one else have the same problem?
Old Nov 18, 2009 | 02:06 PM
fzr's Avatar
fzr
could it be that I forgot the Power Antenna Wire from the deck? or is the power antenna cable for AM only?
ANY INPUT WOULD BE A +
Old Nov 18, 2009 | 11:36 PM
NFSP G35's Avatar
? = 2B || !2B
Hard to say. I've never had a Kenwood, and I've yet to replace the stock deck in the G, but I can tell you this: in the Trans-Am I used to have, the Pioneer deck I put in picked up stations much better than the stock deck did, even though it was using the same antenna. It just had a better receiver. Maybe in your case the opposite is true, maybe the tuner in the Kenwood isn't quite as good as the one in the stock deck? I don't know that that is the problem, just a thought.
Old Nov 23, 2009 | 02:37 PM
fzr's Avatar
fzr
I figured it out, indeed it was the power antenna not hooked up at all, radio works great...no more fading...
Old Nov 23, 2009 | 10:22 PM
azt108's Avatar
My stock radio fades in and out all the time. Not the reception, but the volume. It has terrible reception actually. Sounds to me like I have a loss antenna wire or something.
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
Learned Hand
Oct 1, 2015 09:02 AM
Siciliang35
Sep 18, 2015 11:22 PM
