Need a DIY?
Old Nov 25, 2009 | 02:19 PM
Heist.'s Avatar
Need a DIY?
Just wanted to see if any specific Do it yourself thats in high demand? I have some free time this week
Old Nov 25, 2009 | 02:36 PM
jmueller's Avatar
DIY.. something better with the sunglass holder tray near the mirror.. god that is annoying
Old Nov 25, 2009 | 03:18 PM
4DGS's Avatar
^ plus one, there is very few sunglasses that fit in there.
Old Nov 25, 2009 | 03:21 PM
poloavirex's Avatar
Maybe you can help me
I hate the HID stock that came with my car i would like to change it to an aftermarket HID kit. but Infiniti only use D2S D2R or D2C. would those bulbs look as good as the aftermarkets with a ballast? or is their a conversion adapter from D2C to aftermarket kits??
Old Nov 25, 2009 | 05:00 PM
Heist.'s Avatar
well the sunglass holder problem only makes sense if I have have a specific thing to put in its place... Like a certain garage door opener, or controller for something, etc. It's to vague and anyone that is really going to change it probably will be doing something custom with a mold.
Polo- Really not sure exactly what your saying. If your going for some good bright lighting this is a cheap aftermarket solution. The bulbs are chosen on the right. Check it out. Not sure if that is what you are asking, maybe someone else can help.
http://www.ddmtuning.com/products/DD...5W-101-60.html
Old Nov 25, 2009 | 05:15 PM
TurTLe*'s Avatar
a sedan compression rod DIY is something i haven't seen.
Its pretty straight forward to me as far i saw. But it could help the lesser knowledge people on the board and it can give them the confidence to do it, since it is a VERY common problem
Old Nov 25, 2009 | 06:11 PM
ecuablanco's Avatar
how about replacing the 3rd brake light on the sedan
Old Nov 25, 2009 | 06:24 PM
ShanesG's Avatar
^No DIY need for either of the 2 posts above. thats how easy it is lol
Turtle - is the same as the coupe/z and there are DIY's for those.
ecublanco-squeeze the cover on teh middle, lift the back, push it back a lil and lift the front. done
Old Nov 25, 2009 | 06:44 PM
Heist.'s Avatar
well that cleared it up ^.
I will think of something I have like 4 that I need to write up tomorrow.
Old Nov 25, 2009 | 07:01 PM
XDR-V35's Avatar
hey Heist if you want to add a brembo brake swap ill try and get some more pics before i deploy. i allready have a write up just need more detailed pictures. also on your lug replacement diy, the back ones are a little more dificult, took a little thinking to swap my 60mm nismo studs, front was cake.
Old Nov 25, 2009 | 07:53 PM
NFSP G35's Avatar
? = 2B || !2B
Heist, did you ever get your shiftboot from locksmith? If so a DIY install on that would be nice. It's not hard to do, but I've still seen some have questions about it.
Old Nov 25, 2009 | 08:04 PM
FlyingLumpia's Avatar
Heist are you doing a projector mod. If so a diy would be great on that.
Old Nov 25, 2009 | 08:52 PM
XDR-V35's Avatar
^+1 on the projector mod. I have a good idea on how to do it, but still not cut and dry.
Old Nov 25, 2009 | 09:25 PM
Wiseman's Avatar
compression rod bushing swap
Old Nov 26, 2009 | 04:28 AM
Heist.'s Avatar
Great input everyone!
XDR-V35 - If you have a DIY for those and want me to post it on g35mods.com pm me! I will give you full credit. Just trying to help the community . Also yeah I never got around to the back, sorry.
As far as the projector mod. That is still a work in progress. I did mine and have a write up, but getting the correct cut off and aiming is being very difficult. If I can get the science down I will post up a write up. Def on the list to do.
And the compression rod bushing. I would like to do that in the future. Good idea I will look into it.
Currently also thinking about putting up a basic lube for the joints on the front and back. I did it a long time ago and it seemed to help quiet everything down.
