Difficulty in changing to 04.5 5AT shift knob?
Old Aug 23, 2004 | 04:44 PM
tgenius's Avatar
Difficulty in changing to 04.5 5AT shift ****?
I sat in a Sedan in the showroom today waiting for my wheels and saw the new 04.5 shift ****.. I like it ALOT better.. not as big and bulky. Does anyone know how much they run, and also how difficult it would be to swap one in?
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Old Aug 23, 2004 | 05:39 PM
Britishbloke's Avatar
Re: Difficulty in changing to 04.5 5AT shift ****?
I didn't know there was a different one from the 04 too 04.5..I'd be curiois too see a pic of the newer one...any pics out there?
Old Aug 23, 2004 | 05:49 PM
tgenius's Avatar
I can't find a picture, but its the same shift **** on the FX35/FX45 (if that helps?) It looks alot nicer and its a tighter design.
Old Aug 23, 2004 | 07:06 PM
GeeSpot's Avatar
Hmmmmm..... the new one looks effeminate to me.
Old Aug 23, 2004 | 08:09 PM
Got you, I had an FX35 loaner out recentley..it is smaller.
Old Aug 24, 2004 | 02:31 AM
skeleton_cru's Avatar
Sedan
If it's the same set-up as the '03 there shouldn't be any problem switching them. It's a pretty simple design.
Old Aug 24, 2004 | 05:28 PM
tgenius's Avatar
Ok.. according to Danny at Grubbs, to change the shiftknob involves changing the solenoid, and its $500 + labor!!! I don't get it, it's the same shifter, isn't it?
Old Aug 24, 2004 | 06:35 PM
Sedan
If that's the case, it can't be the same shifter as the '03 5AT. Mine was all mechanical inside, just a simple metal plunger that was inside the shaft. No solenoid involved.
Can you take a couple of pictures of your shifter and post them or email them to me?
Old Aug 24, 2004 | 07:32 PM
tgenius's Avatar
the 04 and 03 shifters are identical..but the shifter in the 04.5s is the FX shifter... I don't exactly understand what the difference is..something doesn't click in my feeble brain
Old Aug 26, 2004 | 11:40 PM
Chiphead's Avatar
Dudes,
Grubbs is smoking dope! I did my '03.5 to the 04 shift **** in about 20 minutes. All you need is the shift **** and the compression adapter, part # 34951-CG000. It's the same **** in the AT 350Z. Sorry for the fuzzy pic above but light and close up equaled fuzz from my camera in macro mode. Remove the old **** by lowering the bottom housing with a screwdriver and carefully remove the clip. It will shoot out if you go at it hard. take off the **** and the white adapter on top of the shift column. Put the blue adapter on the top of the column, the fitting is the same. Put the new handle on and test that the button releases the shift lock. Then, what I did was put a grocery store bag over the column letting the column poke a hole in the bag. It gave a nice tight fit so no metal dust would enter the interior. I put the **** back on and got a hack saw and sawed new slots into the column. the old slots are too low but will be hidden by the 04 ****. I pushed the **** down on the column, not the button, while sawing and I sawed where the slots are on the 04 ****. After sawing a groove that was visible, I tested the clip to make sure it fit well and once it did, I removed the bag carefully and tossed it, reassembled the **** and viola, I was done - an 03.5 G with an 94 ****! Nice mod if I say so myself. The button toward the radio is way easier than the side button and it is smaller!!!
'03.5 Silver/Graphite/5AT/4 Dr/Prem/Sprt/Aero/Winter
...Help - Someone's fallen and I'm not getting out of my G!!!
Old Aug 26, 2004 | 11:41 PM
Chiphead's Avatar
Pic #2
JG_G35
Accessories
Feb 25, 2016 01:44 AM
G35fromPA
Interior
21
Sep 20, 2015 08:58 AM
linedr89
Aug 17, 2015 05:11 PM
z_spec
West
Aug 13, 2015 07:38 PM
nervseele
Jul 17, 2015 11:21 PM
