Squeaky Suspension
Old Dec 3, 2009 | 08:28 PM
tdruk's Avatar
Squeaky Suspension
I drove my car home today, and my front suspension was really squeaky when i pulled up the curb and into my driveway. Its 25 degrees here in mn today, but i remember this happening during the fall also. has anyone had this problem? I dont think this is normal..
Old Dec 3, 2009 | 08:42 PM
bbs350z's Avatar
i have i as well. im gonna try some wd40. but its only sometimes, not often
Old Dec 3, 2009 | 09:27 PM
Braintree's Avatar
Generally a squeaky suspension as you describe means that the bushings need to be replaced on your compression rods. This is common on our G's. There's a TSB on this and numerous posts scattered all over the forum also.
WD40 is possibly not the best thing in the long run since it's a dirt magnet. The only real solution is to replace the bushings. I think they make polyurethane based ones now, which are a much better quality.
Good luck and hope this helps.
Old Dec 4, 2009 | 08:48 AM
Mustang5L5's Avatar
Could also be the strut.
Does it make the noise if you push the car up and down from the fender?
Old Dec 4, 2009 | 07:41 PM
tdruk's Avatar
nope no noise when i push it up and down. Im gonna ask my dealer to see if he can get some compression rod bushings since im there tomorrow for oil change and snow tires. I cant seem to find them on the internet...does anyone on here sell them?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
