Quarter Panels?
Old Dec 21, 2009 | 04:58 PM
sammy_G's Avatar
if you replace the rear panels you lose all the factory welds... not worth it in my opinion. from my experience usually when rear quarters need to be replaced from an accident the car is totaled anyway
Old Dec 21, 2009 | 05:05 PM
The Stimulation's Avatar
Originally Posted by OCG35
fixed
Lol. Wheels fit just fine now. No rubbing at all even with a full car. No scraping either
This is for when I decide to go with wider wheels and lower offsets. Thinking about 12s or 13's in single digit negatives. Point is to run less negative camber as well. Max I want is -5, but if I can get it to -4, even better, but it has to match the fronts as well (those fenders will be modified as well).
Old Dec 21, 2009 | 05:12 PM
MEXTEP's Avatar
Last I heard Strafe was working on some fender flares..why not wait?
Old Dec 21, 2009 | 05:17 PM
sammy_G's Avatar
or you could just go to Auto Explosion
Old Dec 21, 2009 | 05:33 PM
Fender flares still wont work. The fender and the inner portion of the fender split away from each other...regardless the inner part needs to be cut and I would prefer to use sheet metal than go with fiberglass since by that time I'll have air bags and driving low to the point where it looks like the wheels are on the fender (but it will clear).
Old Dec 21, 2009 | 05:35 PM
Actually, that's one of the few shops I'm considering, along with R&J, MOB Works, K&W and a few others.
Old Dec 21, 2009 | 05:40 PM
OCG35's Avatar
already mentioned in a PM response
what the hell are you doing in here anyway? Got sedan jealousy or sumthin'?
Old Dec 21, 2009 | 05:46 PM
OCG35's Avatar
you mean over-fenders? Over-fenders might not be a good idea (poser imo) - but actual flared fenders will work.
Talk with AE and have them do similar that they did for me... they'll have to add more material for you though (its sound like you want to go pretty wide)... it wont be cheap - but it will be right!
Or just do a wide body... not my cup-o-tea, but that's really what you're in need of it seems.
Old Dec 21, 2009 | 06:02 PM
Yeah over fenders is poser IMO as well. Fender flares, well, I guess that would require cutting of the fender as well. Rather stick with metal personally. My oopsie for thinking they were the same.
I don't really want to go widebody, trying to refrain from having to modify other parts besides fenders and quarter panels to get more fender clearance.
Old Dec 21, 2009 | 06:07 PM
sammy_G's Avatar
when i'm bored at work i just click "new posts"
and i'll always be a sedan owner at heart
Old Dec 21, 2009 | 06:11 PM
OCG35's Avatar
you should do the worlds first four door coupe conversion!
Old Dec 21, 2009 | 06:15 PM
MEXTEP's Avatar
Was there not already a sedan that welded all 4 door?(I remember seeing pics of this)
Old Dec 21, 2009 | 06:18 PM
OCG35's Avatar
but Sammy is a coupe... I'm saying he should add doors!
Yes, there was a looooonnnnggggg @ss 2 door (sedan to 2 door) - looked stooopid.
So far no one has done my next plan (which is secret for now)... I wonder if I'll be the first ~
Old Dec 21, 2009 | 06:24 PM
Really? Pics of the long @ss 2 door? I only know of the sedan that did a coupe front end conversion. The purrty blue one with TS front.
Old Dec 21, 2009 | 06:29 PM
  #30
MEXTEP's Avatar
The doors even flipped up..Delorean style.
