Sways for the X
#61
#62
It looks pretty straightforward from the FSM.
Front
Rear
Install in reverse order.
Front
1. Remove tire with power tool.
2. Remove undercover with power tool.
3. Remove mounting nut on upper portion of stabilizer connecting rod with power tool.
4. Remove fixing bolt and nut, then remove stabilizer clamp, stabilizer bushing.
5. Remove stabilizer bar from vehicle.2. Remove undercover with power tool.
Rear
1. Remove dynamic damper of exhaust tube.
2. Remove lower side fixing nut on stabilizer connecting rod and remove stabilizer connecting rod from stabilizer bar with power tool.
3. Remove fixing nut on stabilizer clamp and remove stabilizer from vehicle with power tool.2. Remove lower side fixing nut on stabilizer connecting rod and remove stabilizer connecting rod from stabilizer bar with power tool.
#63
1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
_______________
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
_______________
#65
To get this straight would an '06x already have sway bars on it front and rear but this thread is talking about replacing them with stiffer ones? My last car (civic) had no rear sway at all, so I bought one and went to install it myself, and busted the heads off a couple of bolts that were welded in the back. Oops. Took it to the dealer and payed them to fix my mistake and intall it for me and replace the nearly rusted out rear lower control arms. Cost me a chunk of change but the cornering was so improved it was still worth it.
#66
1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
i'm down for a set of sways for my "X"... fo' sho'!
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
#67
The older cars dont have sway bars, ours have them..we're just replacing them with stiffer ones to improve handling.
#68
Any rear sway bar that fits a RWD will fit an AWD, but the fronts are not interchangeable. But there's very little benefit to upgrading just the rear sway on the G35, and not every manufacturer sells just the rear set.
#69
A lot of vehicles do not come with rear bars as a matter of safety. Without a rear bar, the car will tend to push through a turn (understeer) as a matter of design. Most if not all cars today are set up to understeer just because the average driver doesn't know what to do in a oversteer situation.
The stiffer the bar, the more prone that end of the car would be to "step" out in a hard turn. Too stiff of a bar in the rear will cause the rear to want to come around, or oversteer. This is why i am not too thrilled about replacing only the rear bar on a RWD-biased car.
#70
1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
Im in for it too =]
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
Im in for it too =]
#71
on
1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
#72
#74
1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
29. G35-Dan
count me in if the price is right. Send this list to the rep and get a GB going!!
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
29. G35-Dan
#75
[QUOTE=G35-Dan;5023154]1. FlyingLumpia
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
29. G35-Dan
30. Alex2x3
I was just looking into this
2. Bestswat
3. BIGD28
4. Mustang5L5
5. Machine head
6. Turtle*
7. Kevinandmd
8. G35xChicago
9. Bassman
10. ProfanityPete
11. OKStateG35
12. NLAllen141
13. peterbigblock
14. Bauerfeind
15. dt0r
16. mcraerc
17.Gizmo134
18. JerryG35x
19. BuckeyeInMI
20. Holmes35
21. mr.potatohead
22. chrisg35x
23. g-mony
24. John Pich
25. chicoso4
26. RicoG35x
27. TizAlex
28. Pmpjuce06
29. G35-Dan
30. Alex2x3
