2004 Sedan will not idle after start
Old Jan 2, 2010 | 01:28 PM
flhtvtwin's Avatar
I put a new battery in a few days ago. Now the car does not always stay running after starting. I did the Basic ECU reset, the Acc. Pedal released learning, throttle valve closed learning, and the idle air volume learning. I even did the cruising setting of the air/fuel ratio.
Car will stay running if you rev it after starting. It runs perfectly.
Any help or ideas will be appreciated,
Mark
Old Jan 2, 2010 | 01:34 PM
04G35NYC's Avatar
Sounds like the MAF is a problem and is going not sure tho.
Old Jan 2, 2010 | 01:48 PM
itgogitrev's Avatar
How many miles have you driven it? I had a similar problem with mine. I kept the revs up with the throttle and just drove it around for about 10 minutes.
That cleared everything up.
Old Jan 2, 2010 | 04:20 PM
flhtvtwin's Avatar
I've driven the car about 20 miles so far.
Old Jan 3, 2010 | 04:23 PM
G35m@'s Avatar
sounds like a throttle body or MAF issue - quick diagnostics at the dealership should tell you what you need to do - mine does not charge me to hook it up and tell me the problem...I usually go and fix it myself after I know what is exactly wrong.
Old Jan 3, 2010 | 05:11 PM
AARONHL's Avatar
Are you sure you were able to complete the procedure?
Old Jan 3, 2010 | 05:16 PM
flhtvtwin's Avatar
I'm sure I completed the procedures. I had trouble getting the air volume one done. The SES light did not always work as the procedure said, probably a timing issue. I was using a watch to count the seconds.
The problem has to relate to the battery change, doesn't it? I don't see how the MAF or throttle body could be a problem since all was okay before the battery change. I even used my scanner and no problems are indicated.
Mark
Old Jan 3, 2010 | 05:22 PM
AARONHL's Avatar
How long was your battery disconnected for? Did you correctly perform the procedure when the SES light did work?
Old Jan 3, 2010 | 05:37 PM
flhtvtwin's Avatar
Battery was disconnected for about 20 minutes. Yes, I did the procedure per the service manual.
Thanks,
Mark
Old Jan 3, 2010 | 11:34 PM
Tollboothwilley's Avatar
maybe your battery has a loose connection
Old Jan 8, 2010 | 04:27 PM
flhtvtwin's Avatar
Fixed
Car readjusted itself now, is working great, no more stalls.
Muski_G
Dec 1, 2023 11:11 AM
TheKnite
Aug 14, 2015 07:59 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
