G35 Clock Light
Old Jan 8, 2010 | 12:13 PM
MJW's Avatar
MJW
G35 Clock Light
I recently had my CD changer replaced. When I picked up the car the light in the clock no longer worked. The dealer says its a coincidence. Any idea whether there could be a correlation to the work done replacing the changer? Thanks
Old Jan 8, 2010 | 12:31 PM
davidm99's Avatar
20 Year Member
Sedan
This issue has been posted before and if you searched a little you would have probably found something. I just saw that there is another post about the same question on Jan 5 about 15-20 theads down.
This is a known issue when changing out the cd changer. This happened when I swapped out my OEM radio/cd changer for an aftermarket head unit. Not sure why it does this but it happens.
It is pretty easy to change out the bulbs or replace them with LEDs. See the following link.
https://g35driver.com/forums/lightin...ent-guide.html
It talks about replacing with a new bulb but later on there are mentions of how to replace with a LED.
Old Jan 9, 2010 | 07:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
Coincidence my azz. Take it back to the dealer and demand they fix it for free. Make them give you a loaner G37 and have fun in it for a day.
Old Jan 9, 2010 | 11:17 AM
NjMatteSedan's Avatar
^ +1 lol, don't let em off the hook that easy
Old Jan 10, 2010 | 12:27 PM
Tollboothwilley's Avatar
Come on guys. It takes 3 sec to connect the wires. The plastic bezel around the light pulls right out and then all you have to do is plug in the clock.
Jusseth
Sep 13, 2020 12:25 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
