tanabe Df210 springs in a sedan
Old Jan 12, 2010 | 07:08 PM
GeNOS's Avatar
hey was just wondering if anyone had pics of sedans on these springs...
just wanna see how it sites before i order some
thanks
Old Jan 12, 2010 | 10:24 PM
GeNOS's Avatar
been reading a heap of old threads and seen alot of people saying the tanabe springs are too soft for a lowered car...
would the Eibach G35 Sedan sportline progressive springs 1.6"/1.6" drop be a beter item to go with?
Old Jan 12, 2010 | 10:52 PM
5150DS's Avatar
If you lower the car that much you want to consider front and rear camber kits also. Your tires will wear very fast if you don't.
Old Jan 12, 2010 | 10:56 PM
GeNOS's Avatar
yeah i know lookin into them aswell
what are teh camber kits worth?? 350z items fit sedans?
if i stuck COUPE Tien S-Techs (1.2 and 0.9) in my sedan would i get a 1.7 and 1.4 drop?
Old Jan 13, 2010 | 12:07 AM
4DGS's Avatar
^yes
I'm putting coupe S-techs in my front and leaving my Sedan H-techs in the rear.
1.7 and 1.4 will look incredibly stupid. WAY too uneven.
5150DS's Avatar
Look here: https://g35driver.com/forums/suspens...tires-___.html
Old Jan 13, 2010 | 12:13 AM
GeNOS's Avatar
Originally Posted by 4DGS
^yes
are you puting them on the sedan struts tho??
1.7 and 1.4 is only like 7mm difference... the front is higher to start with, so the extra bit lower at teh front will help level it out wouldnt it?
Old Jan 13, 2010 | 12:18 AM
4DGS's Avatar
Might but might look weird. I've been considering installing the coupe S-techs and seeing how they look. Yea stock, sedans struts, until they blow. Then I'll either pick up some used aftermarket ones or go coilovers.
Old Jan 13, 2010 | 12:29 AM
MEXTEP's Avatar
https://g35driver.com/forums/19-inch...ont-tires.html
I am lowered on them and with the wheels you see pictured it is low..I am rolling on coupe 18s and it raises up a little based on the tires.
Old Jan 13, 2010 | 12:41 AM
GeNOS's Avatar
"them" being the tanabe? or the coupe S techs??
Old Jan 13, 2010 | 12:45 AM
MEXTEP's Avatar
Tanabe
Old Jan 13, 2010 | 12:52 AM
GeNOS's Avatar
do u find them to soft?
Old Jan 13, 2010 | 12:59 AM
Fr3shIngredient's Avatar
try to use the search, cause there's alot for sedan's with these springs and they have pic too.
Old Jan 13, 2010 | 01:21 AM
GeNOS's Avatar
i had been searching and reading for a few hours before i made this thread....
Old Jan 13, 2010 | 01:24 AM
MEXTEP's Avatar
Not initially..guess my shocks are starting to loose their bounce..it rode almost stock
