What's the correct hub ring size?
Old Jan 12, 2010 | 09:50 PM
Vancouver_G35's Avatar
I just got a new set of Enkei GTC01 rims. Their website states that it has a 75mm center bore. The G35 has a 66.1mm center bore. Based on that, what is the correct size for the hub ring? Should I buy a ring size that matches the measurement exactly (75 outside diameter and 66.1 inside diameter) or do I buy it a bit short of that size (74 outside diameter and 66.2 inside diameter? My buddy bought a set of rims from Tirerack and the rings that came with his wheels fit perfectly snug. I want the same. Please help.
Old Jan 12, 2010 | 10:41 PM
HwyDrftr's Avatar
I was wondering the same thing, I plan on measuring the stock wheel and the hub to see what the tolerance is but haven't got around to it, I would guess though that they thought of this when they make the rings and the sizes are nominal with the tolerance built in.
Old Jan 13, 2010 | 12:30 AM
G SEDAN's Avatar
you have to order a hub ring that is 75mm outer and 66.1mm inner. are you sure its 75mm though? Your shop should've included them for free that's what I think!
you can buy customized sizes here.
http://www.justforwheels.com/index.jsp?cat=hubcentric
Old Jan 13, 2010 | 12:57 AM
Thanks but that site doesn't really help me because they don't list the specs unfortunately. Also they don't ask you which wheel within a certain brand you have. They have one generic hub ring for Enkei. But the Enkei have different bore sizing per wheel design and even different bore sizes within a style depending on the size of the wheel.
Old Jan 13, 2010 | 01:15 AM
Jeff92se's Avatar
Red Card Crew
custom http://www.motorsport-tech.com/hub_rings.html
Or ask Enkei if they have the right hub centric rings available
Old Jan 13, 2010 | 03:12 AM
Looked around the interweb some more and I think I've found my answer. The hub ring size is based on the exact bore size of the wheel and hub flange. So the correct size would be 75mm x 66.06mm (or 66.1mm as its sometimes rounded up). In case you're wondering, plastic seems to be recommended over aluminum because there is no risk of corrosion.
Old Jan 13, 2010 | 06:37 PM
OCG35's Avatar
just get these: http://www.z1auto.com/prodmore.asp?m...ls&prodid=4524
Performance Nissan (mynismo.com) has them too - I couldn't find them on their site, but that's where I got mine (aluminum).
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
RAVSPEC
Jul 16, 2015 01:58 AM
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
