please help!
Old Jan 16, 2010 | 11:53 PM
thatsmyG35's Avatar
please help!
I intalled a jwt pop charger and a z tube a couple of days ago and seemed to run just fine the first couple of days now the car has a hard time accelerating and at idle it chugs and eventually dies. is it not getting enough air? what's the deal?
Old Jan 16, 2010 | 11:55 PM
mapleleaf13's Avatar
could be your MAF sensor was damaged when you did the install ??
Old Jan 17, 2010 | 10:54 AM
G35Papa's Avatar
^That would suck cause they are expensive to replace. Try getting some MAF cleaner as well and clean it if you haven't already.
Old Jan 17, 2010 | 02:24 PM
Blue Dream's Avatar
I drove ttrank's car solo
Check to make sure the vacuum tube is securely fastened to the z tube. Could be a cause of your symptoms.
