crazy fuel consumption on my 03 sedan...
Old Jan 17, 2010 | 02:35 PM
melo's Avatar
i've had my G for nearly one and a half years and i love it. it was running ok with 15L/100km at the beginning, i knew it's a 3.5 V6 and that VQ is not good on gas blah blah blah. but recently it's drinking up gas like crazy! 20L/km and im not even pushing it hard! rarely exceed 3000rpm!!! i just dont know what the hell is going on right now, like a V6 engine consuming fuel like a V10? it's pissing me off...
should i be checking anything over? i honestly dont wanna take it to the dealership cuz those dumbasses will only give me answers like oh it's got a V6 engine and maybe it's the way you drive it...
ps: it's the doggy door sedan, just in case any doggy door owners have the same problem as i do, i would feel better if there is tho...
Old Jan 17, 2010 | 03:21 PM
Swivel's Avatar
Moderator
Maybe a simplistic question, but is your air filter fresh and clean? I'll let others with more experience chime in, but maybe a MAF cleaning would help, too.
Haven't checked my mileage recently but I'm sure my DD sedan isn't doing 20/100
Old Jan 17, 2010 | 03:38 PM
maciejk's Avatar
have a look at your spark plugs, use premium if you currently aren't you might get a better mileage than on 87, check your tire pressure, 32psi minimum,
Old Jan 17, 2010 | 03:49 PM
Mustang5L5's Avatar
How many miles are on your car?
Might be time to start doing such tune-up items as mentioned above. Also, run the codes and see if anything fo the o2's come up. I've sometimes seen codes stored in vehicle memory even without a CEL on
Old Jan 17, 2010 | 04:38 PM
melo's Avatar
thanks fellows. i currently have 60k Kms on it, not driving it alot. i was thinking to change air filters and spark plugs, maybe that would be the cause
what is a MAF cleaning? is it the one that cleans the fuel injectors?
Old Jan 17, 2010 | 05:28 PM
David.A.C.'s Avatar
Well if it only has 60,000kms on it, than it's probably not even the spark plugs because they're supposed to be good up until 100,000kms . Air filter sounds more like it. Just change the filter and if it's still drinking gas like a pig than try the MAF cleaning. Mass Airflow Sensor (MAF) is one of the components of an electronic fuel injection system and is installed inside the intake air duct between the air filter and the motor. It is used to measure the amount of air entering the engine, and that measurement is used by the engine computer or ECM to calculate the proper amount of fuel injected into the cylinders to provide optimum combustion and low emissions.
But normally when a MAF is damaged or if it is dirty, it can possibly cause a wide range of problems such as stalling especially when the motor is cold, misfiring, poor acceleration, etc.
In addition, have you noticed your "check engine" light in the instrument panel to turn on?
Old Jan 17, 2010 | 06:10 PM
melo's Avatar
thanks for writing so much man lol
maybe MAF is the case, i've had a few misfiring recently, and i'd have to say that acceleration is poor too.
how much does it usually cost to get it checked and fixed up?
ps check engine light was never on
Old Jan 17, 2010 | 07:06 PM
David.A.C.'s Avatar
The MAF is a delicate piece of equipment so just be careful on how you clean it because if you damage it, it's pretty expensive to replace it. But sorry i don't know how much it costs to get it checked and fixed because I have never taken my car to have it cleaned. I just cleaned it myself.
Old Jan 17, 2010 | 08:48 PM
4DGS's Avatar
I have nav it tells me, I have never seen my car go over 13L/100km... except when I got my exhaust and intake done.
Changing your plugs might be a good idea to see if there is any oil on them. If there is you could be in for trouble. I say change your intake filter and see how that goes before doing anything series.
Old Jan 17, 2010 | 09:35 PM
Mustang5L5's Avatar
Cleaning the MAF is easy. Basically you just go to radio shack and get electronics cleaner and spray down the filament wires inside the MAF.
Usually guys who put K&N's on and overoil them get their MAF wires coated in oil affecting the readings.
Also, an ECU reset might be a good idea, but i'd see if any codes were stored first
HOWEVER...if you are still covered under warranty, don't do a thing...take it to dealer
Old Jan 22, 2010 | 06:40 PM
melo's Avatar
i'm covered under an extended warranty, which would not be helpful in my case...
how to read codes stored in the ECU? and how to reset it? i've read several threads regarding how to reset ECUs but they all use different methods, and most of them are not for doggy 03's since doggies have older ECU, correct me if im wrong
Old Jan 22, 2010 | 08:36 PM
nghiars's Avatar
clean air filter? oil change? tire pressure?
Old Jan 23, 2010 | 02:02 AM
socialconflicts's Avatar
i did tire pressure recently and my nav is reading 5mpgs better now. im happy
Old Jan 23, 2010 | 12:24 PM
Tollboothwilley's Avatar
You probably have a leak in your fuel system. There was a guy who was going through the same issue. Was getting like 200 miles on a full 15-17 gallons. I can't remember his name though. Let me see if I can find the thread.
Old Jan 23, 2010 | 02:29 PM
melo's Avatar
oh really! then should i take it to the dealer? thanks for your time man!
