M3 Lip
Old Mar 29, 2010 | 02:01 AM
  #151
jattg35's Avatar
Originally Posted by thescreensavers
Send him a message
perfect will do. thanks.
Old Mar 29, 2010 | 01:41 PM
  #152
OCG35's Avatar
Originally Posted by NFSP G35
^Who me? No. Waiting on paint. The shop is probably going to mold that in with everything else from the wreck.
fixed
Old Mar 29, 2010 | 01:43 PM
  #153
OCG35's Avatar
I'm going to have them do it on the damaged side. If it's not too much, I'll get them to do the drivers side too. If it is too much for me to swing right now, I'll just 3M the moldings back to the shaved passenger side so it will match until I can save enough for the drivers side.
^Yep
make sure they do it right (welding holes and spend the proper time getting it straight/smooth)... there are cheap ways to do it (bondo) but it can end up wavy and may not last... the "correct" way isnt cheap - but better than paying to fix it later...
Old Mar 29, 2010 | 02:01 PM
  #154
NFSP G35's Avatar
? = 2B || !2B
The guy that fixes body stuff is surprisingly good. I'll leave it to his descression.
Old Jun 3, 2010 | 05:07 PM
  #155
thescreensavers's Avatar
Mr.202?
So did 1165mm work?
Old Jun 3, 2010 | 05:29 PM
  #156
NFSP G35's Avatar
? = 2B || !2B
^Thanks for finding and bumping this thread... you saved me having to look for it LOL!
I mounted mine dead-flush to the back of the trunk lid, so it ended up being about 6mm short on each side. I need to look up exactly what length I told them to cut it.
Old Jun 3, 2010 | 05:40 PM
  #157
NFSP G35's Avatar
? = 2B || !2B
Ok... I ordered mine from oem.thing unpainted 1163mm, had it painted, and installed it perfectly flush against the back edge of the trunklid... Because of the taper of the trunk, it would have probably set closer to each edge if I hadn't followed the curve of the trunk so closely, but I felt it needed to mount that way.
This left almost exactly 6mm gap on each side (not really bad, but not perfectly flush)
So, just to err on the side of caution, I would round down to 5mm on each side, and say the "perfect length" should be: 1163 + 5 + 5 = 1173mm.
Old Jun 3, 2010 | 05:41 PM
  #158
NFSP G35's Avatar
? = 2B || !2B
Old Jun 3, 2010 | 05:54 PM
  #159
socialconflicts's Avatar
1165mm fit flush for me.. maybe 1166 would be best but i say 1165 is perfect.
Old Jun 3, 2010 | 06:04 PM
  #160
NFSP G35's Avatar
? = 2B || !2B
^Did you go perfectly flush against the back edge of the trunk lid though?
Old Jun 4, 2010 | 03:26 PM
  #161
Mr.202?
^ nice getting it flush like that, mines a fooking mess lol
Old Jun 4, 2010 | 03:29 PM
  #162
the back is perfect, there is light space on one side, why im thinking maybe 1166... but i wouldnt risk it... 1165 has already been said is perfect fitment.
Old Jun 4, 2010 | 05:54 PM
  #163
NjMatteSedan's Avatar
1165mm with the lip flush to the back of the trunk lid. has to be adjusted to the left a couple mm
Old Jun 4, 2010 | 09:04 PM
  #164
NFSP G35's Avatar
? = 2B || !2B
^Yeah, they must have cut mine wrong... Mine is "1163" and yours is 1165, but looks a lot more than 2mm longer :/
Old Jun 4, 2010 | 10:13 PM
  #165
Mr.202?
I have Updated OP
