Rear Windows Not Rolling Up
Hey.. I have a 05 Base Sedan... Whenever I Roll down the Rear Windows from the Drivers Window Control, I am not able to roll them back up using the drivers control. They willl only roll up with the rear seats control. Anybody know a fix for this?
Mine is currently doing the Opposite. The left rear window will only go up using the Drivers Control, but from the left rear control it works fine. I figure rain water fell into it, since I smoke and usually keep the drivers window cracked.
Going to rip into it this weekend. Im sure its a bad wire or a corroded connection.
It was happening to mine, too. My car overheated on my wife and used my extended warranty to pay for the towing and repairs. I asked if they could also fix the window switch issue at the drivers and they took care of it. I believe the switch had to be replaced at the driver's side. Use your factory warranty if you can.
Hey by any chance would you know how i can fix this issue?
my back window wont go up it will only go down so i thought that maybe:
1) the motor was bad so i tested that motor on the other side and it worked fine
2) maybe the switch was bad so i tried the switch on the other side and it also worked fine
So basically all the hardware works window motor and switch but it wont go up..... any idea?
All the connectors are also fine and it still wont go up from the front nor the back switch
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
will091195
Jul 27, 2015 09:19 PM
