Latest UOA on M1 10W30...
Old Sep 8, 2004 | 10:35 PM
chinee's Avatar
... not good! I'm not sure if it's my VQ or my driving habits, but I always seem to get higher than normal lead wear in my UOAs. I use the same oil in my Sequioa and get excellent results yet my VQ seems to get some real abuse. I will likely leave this fill in only for 4 - 5K, and switch to something else; hopefully I'll get a recommendation from BITOG.
I haven't posted this UOA on BITOG yet, but will tomorrow; I will probably email Terry Dyson to get his input as well. At this point I'm ready to head back to dino, maybe GTX with a 4K OCI and see how that pans out.
Talk about a downer... it appeared that the lead wear was trending downwards, so I was hoping that it would be closer to normal this time around, but **** man!.. I'm so pissed not knowing what I'm doing wrong. I don't race at all but I do drive aggressively and use the MM frequently.
Mostly "city" miles now but not typical city, more like suburbia miles. Fourteen miles to work and I only encounter about a dozen traffic lights, and no stop and go traffic. I'm driving less now, about 1300 miles per month vs. 1800 miles monthly a year ago. I use no additives in the fuel nor oil. Purolator Prem Plus oil filter.
g-owners.com... feel free to post this on your site.
<font color=red>chinee</font color=red>
03.5 G35s
Old Sep 8, 2004 | 10:36 PM
chinee's Avatar
Re: Latest UOA on M1 10W30...
UOA
03.5 G35s
Old Sep 9, 2004 | 01:18 AM
IQ9's Avatar
IQ9
It seems to be that your motor is different? They stated that you seem to be the only one seeing this issue so what can you do other than change your driving habits which you have already done. I would drive it and not worry.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHERE ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
Old Sep 9, 2004 | 10:47 AM
3point5SE_Auto's Avatar
is 15w-30 an option or 10w-40? just an idea
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Sep 9, 2004 | 12:05 PM
G35_TX's Avatar
Try Amsoil. My results were very good for a 6k miles on the oil.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, Stilen CAI
Track: 14.32 at 98.79 mph 2.2032 60ft
Dyno 07-07-04 - 234.2 hp & 233.8 tq
http://www.g35world.com
Old Sep 9, 2004 | 12:06 PM
G35_TX's Avatar
Old Sep 10, 2004 | 01:49 PM
GeeSpot's Avatar
Please don't get upset with me over this...it is an honest question and not a dig.
It is my understanding that Nissan/Infiniti recommends dino oil in the VQ engines. If this is correct maybe they know something that makes them lean in that direction. I just wondered why you and others run synthetic counter to the manuf. recommendations? Again, not flaming, just wanting to understand the why behind the initial switch to synthetic. Thank you.
Old Sep 10, 2004 | 02:17 PM
SixFive's Avatar
My dealer tried to sell it to me
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Sep 10, 2004 | 02:50 PM
MiamiG35sedan's Avatar
I'm curious:
"It is my understanding that Nissan/Infiniti recommends dino oil in the VQ engines."
Where exactly did you get this understanding from?
2004 Sedan 5AT STS
Huper Optik Ceramic 50/Underbody Diffusers/Clear Corners/Brake Cover
GroundingGear 7 Wire/Z-Tube/Stillen High Flow Airbox/HKS Sport Exhaust/Technosquare F-Spec ECU
Old Sep 10, 2004 | 06:23 PM
chinee's Avatar
There are two versions of the owner's manual... I believe the most current version says mineral based oil is recommended, while the initial manuals state just the minimum oil rating required.
I'm not an oil expert only a small oil "hobbyist"; I follow the tests and UOAs and occasionally update myself on BITOG.
Synthetic oils provide far superior lubrication than conventional oils. The superior lubrication better protects metal surfaces, reduces wear and flows more easily, the latter being extremely important during initial start up and the first minute of idling when all the oil is in the pan. My understanding is that using synth is always an improvement.
But there are still so many factors involved in making an engine run, that the oil factor may be so small that it could be considered inconsequential. I ran my last car, a 96 Altima, to 170K miles, changing the (conventional) oil fairly infrequently (anywhere between 5-10K), and it still ran and never consumed oil up to the day I sold it.... in fact, it's still on the road 18 months later. So how important is oil really, synth or dino? ... probably as important as your psyche (sp?) tells you it is....
03.5 G35s
Old Sep 10, 2004 | 06:28 PM
GeeSpot's Avatar
I got that impression from reading on this and other G35 Forums - hence why I phrased it as "my understanding" and not as a "fact". I decided to look for myself. In section 10-5 of the manual under Technical and consumer information - Engine Oil and Oil Filter Recommendation I found the phrase "Infiniti recommends mineral based oils."
Is this why some people state that Infiniti recommends dino(natural) rather than synthetic oils?
Old Sep 10, 2004 | 07:37 PM
YOU ARE CORRECT! I just checked my 2004 manual, and in section 9-5 it has the exact same statement about mineral based oils. Thank you. I guess I'm going from M1 back to dino.
2004 Sedan 5AT STS
Old Sep 15, 2004 | 06:30 AM
cato's Avatar
SouthernComfort Moderator
I'm no expert, but I have heard that Castrol Syntec synthetic
oil is a mineral based oil. Using Castrol Syntec could offer the
best of both worlds to our G35s.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 15, 2004 | 07:48 PM
JimG35's Avatar
This is a common discussion topic in every automotive forum. My opinion is that synthetic really pays off in the long run. Engines don't "age" when on synthetic. I bought a new dodge (a truly generic car) and beat the crap out of it for 240,000 mile and its engine is as strong, clean (inside & out) and a 2 yr old. Dino or synthetic you won't see the difference for 100,000 mi. After that you will.
http://www.exxonmobil.com/Corporate/...r_050104_1.asp
Old Sep 16, 2004 | 03:23 PM
GurgenPB's Avatar
Chinee
My UAO has been in for a while, just scanned it in, will post it later tonight. But, I too have increased Pb wear, like you do, but i only had the oil in for less than 3000 miles. Turbos are kinds hard on the engine i guess. I too will be getting a recommendation from BITOG
G
