Re: Trunk fix???
Old Mar 7, 2010 | 11:51 PM
C63someday's Avatar
Re: Trunk fix???
Ok so i got my G about 3 months ago, 2 Days after i got it the trunk stoped working, Long story short i found the 9 wires 5 of which were broken, I soldiered/ heat shrunk the broken wires, I try to use my trunk as little as possible, Ive maybe used it 10 times since it was fixed, AND IT DOSENT WORK AGAIN!!!!!!!!!!!!!!!!!!!! Anyone got a longterm fix for the trunk issues? Or should i sell this over priced underbuilt p.o.s before something else breaks?
Old Mar 8, 2010 | 06:37 PM
NFSP G35's Avatar
? = 2B || !2B
^Congrats, you've found a problem I've never heard of
It's not something simple like having the doors locked right?
Old Mar 8, 2010 | 06:40 PM
LordFappington's Avatar
Did your wiring have the rubber shroud that tucks into the trunk itself? It should be oversized for the hole and you are supposed to jam it in there, if not the only thing I can think thats happening is your wires are crimping somehow in the lift assembly.
Old Mar 8, 2010 | 09:03 PM
bigwilly's Avatar
If it makes you feel any better, I had to do mine 3 times now. Once by the dealer under warranty and two by myself. Make sure the heat shrink that you use isn't really thick and stiff that may cause the wire to fray at the end of the heat shrink. That is what happened with the dealer fix.
Old Mar 10, 2010 | 02:42 PM
C63someday's Avatar
I used the softest heat shrink i had, this will be the 3rd time to fix this once dealer 2 me, And yes i have the rubber gromet that goes into the trunk,
Old Mar 10, 2010 | 07:38 PM
Gnightsedan's Avatar
My trunk is always randomly getting stuck, but it never fails when the dealer checks it out
Old Mar 12, 2010 | 09:17 AM
35bills's Avatar
Welcome to the club!!!
I just had mine repaired yesterday. It's the second time for it to happen.
First time was under warranty and the stealership said that they replaced the entire wire harness...what BS I found out last night. They had my car for two days, never replaced any harness..just replaced the wires from the trunk/lights into the main harness.
Had it corrected within two hrs at my mechanics place. He wasn't too impressed with my former dealership to say the least.
Bigwilly, did you deal with Agincourt to get it repaired?
Old Mar 13, 2010 | 12:43 PM
wuppiedog's Avatar
trunk release repair
My trunk release failed due to broken wires in harness. Dealer "repaired" using solder and tape, but this failed again in a couple of weeks. I repaired it again myself using plastic in-line splice crimp connectors you can get at Radio Shack or Home Depot (about $2 for 10). I then used black friction electrical tape to wrap up the wires and connectors. This has worked well for a couple of months. This is a more durable fix since the dealer's wire soldering job came loose. You shouldn't solder 16 gage wire ends together!
Old Mar 14, 2010 | 11:01 AM
flhtvtwin's Avatar
Can someone post pictures of this problem area?
I'd like to check my car's wiring in case the same rubbing condition is there.
Old Mar 14, 2010 | 12:48 PM
C63someday's Avatar
Pop your trunk, You will see where the harness goes into the trunk lid on the right side, Peel back the harness cover and check for damaged wires, Id also like to thank hyatt infiniti in calgary alberta canada for using all the same color wires to fix it!! nothing like 9 broken red wires.
ara777
Oct 25, 2017 01:45 PM
lil beezy
Accessories
Sep 8, 2015 07:23 PM
Albanian122
Sep 7, 2015 07:41 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
