painted my 06 calipers today
Old 03-25-2010 | 02:37 PM
dsmmyth's Avatar
Originally Posted by MissouriG35
did you put the springs on backwards (fronts on rears?) What springs did you get?
Says in his sig he got 350z S-Techs. ^
  #77
NjMatteSedan's Avatar
Dang your car is tall. 4x4 badges should be your next mod
  #78
Old 03-25-2010 | 02:40 PM
Matzo Ball's Avatar
Good lord, those should lower him 3.5 up front and 2.8 rear.
  #79
Old 03-25-2010 | 02:41 PM
dsmmyth's Avatar
Lawl. I hate to say it, but he needs it.
See:
  #80
Old 03-25-2010 | 02:42 PM
Matzo Ball's Avatar
See:
haha true. The tires make that gap look larger as well. Happy slamming!
  #81
Old 03-25-2010 | 02:44 PM
NFSP G35's Avatar
? = 2B || !2B
Maybe you put the springs in upside down, so instead of lowering the car 2" it lifted it 2"
....I jest
  #82
Old 03-25-2010 | 02:47 PM
Matzo Ball's Avatar
....I jest
I cannot image the front 2" higher OP, just having fun
  #83
Old 03-25-2010 | 02:50 PM
Matzo Ball's Avatar
To get an idea, this is what mine looked like prior to my drop and w/ Coupe 18s. 245/40 tires.
  #84
Old 03-25-2010 | 09:06 PM
jimmyc13's Avatar
Dude, pretty sure he's fvcking with us/kidding w/ that response and responding to why his car is so high...really don't think he's dropped yet in those picts...
  #85
Old 03-25-2010 | 09:54 PM
Matzo Ball's Avatar
you are right, in the pics he is not dropped. He stated that when installing the springs, the stance seem off up front (up 2")
  #86
Old 03-26-2010 | 06:49 PM
badman70_1's Avatar
it looks like his car has hydraulics.......hit them switches man....hit them switches.....
  #87
Old 03-26-2010 | 09:17 PM
SN00P's Avatar
CLUB MODERATOR
i was kidding about about all ready putting a drop on it i was being sarcastic ... i honestly dont think i will drop 3 or more inches from the 350z s-techs cause if you look them up they are no more then .8 i found .. almost every site i look at the drop is different .. im thinking with the +1'' i will be around 2'' all the way around .. and the gap i have right now is 2''
and missouri yupp your car looks like mine when it wasn't dropped ... i got paid today !!!!!!!! so im trying to get in a local shop for fender rolling saturday so hopefully i can get it and then i will install my springs
  #88
Old 03-26-2010 | 09:26 PM
SN00P's Avatar
CLUB MODERATOR
hmmm i wonder if i can find some 24s chrome for now till the drop gets put on and be GANGSTA !!!
NOTTT
  #89
Old 03-26-2010 | 10:26 PM
Matzo Ball's Avatar
happy slamming
  #90
Old 03-26-2010 | 11:17 PM
nazc0's Avatar
Originally Posted by BuckeyeInMI
On a stock suspension that's running at the correct ride height, you won't rub. That tire is .3" smaller than stock so you should have at least an inch of clearance between the tire and the wheel well. The offset wouldn't matter, as it will only tell you if you're outside the wheel well or not, but you should be well below the wheel arch regardless. If you're rubbing, and you're not lowered, then something is wrong with your suspension. I can pretty much guarantee it.
Take some pics and maybe we can see if there's a problem. And measure from the ground to the highest point on the bottom of the wheel arch. From what you're saying, it's going to be around 26", the same height as your 26" diameter tires, which is at least an inch lower than stock ride height. You may not be intentionally lowered, but that doesn't mean your springs are functioning correctly.
BTW, I agree with you on the rolling. If in doubt, just get them rolled.
they only rub with a full car of people or when going over a speed bump to fast
i dont care about my springs and shocks that much right now im getting coilovers soon
Quick Reply: painted my 06 calipers today
