Autodim Rearview Sensitivity
Old Mar 27, 2010 | 09:13 PM
Hearno's Avatar
Is there any way to increase the sensitivity of the autodim feature? Most headlights aren't bright enough to turn activate it which is annoying. As I recall, my 2001 Maxima's could be turned on and off.
Old Mar 28, 2010 | 06:35 PM
Hearno's Avatar
Anyone?
Old Mar 28, 2010 | 08:01 PM
Deepdiver's Avatar
yes you can turn it on and off, but you can not adjust sensitivity.
Old Mar 28, 2010 | 08:11 PM
Hearno's Avatar
By on I meant permanently at the darkest level but I got you. Infiniti needs to tighten up.
Old Mar 28, 2010 | 08:39 PM
Deepdiver's Avatar
just tilt the entire mirror up a little bit...it will be like if you have a manual tilt/glare adjustment lever.
Old Mar 29, 2010 | 06:41 PM
Mustang5L5's Avatar
Mine is pretty dark when it's on. Are your sure your's is working properly?
Old Mar 30, 2010 | 12:15 AM
Sceptor's Avatar
+1 ^ same here
Old Mar 30, 2010 | 01:25 PM
Alphecca's Avatar
I have the same issue as Hearno...it does dim, but not until the following lights are kinda unpleasant.
Old Mar 30, 2010 | 01:32 PM
Alan's Avatar
i dont think ive ever noticed mine dim since the day i got the car
Old Mar 30, 2010 | 01:52 PM
Deepdiver's Avatar
Try cleaning off the sensor...perhaps dust or something is reducing the sensitivity.
Old Mar 30, 2010 | 03:11 PM
Bestswat's Avatar
Or get some rear tints
Old Mar 30, 2010 | 03:17 PM
Sceptor's Avatar
or get a new car
Old Mar 31, 2010 | 12:54 AM
Hearno's Avatar
That's a good call, it never even occurred to me.
Old Apr 21, 2010 | 09:16 PM
jvm0685's Avatar
where's the sensor located?
Old Apr 21, 2010 | 11:05 PM
coolieman1220's Avatar
i've noticed that the german cars mirror tinting systems are far superior then to that of the japanese...as with everything else! window tint also helps to eliminate glare
