'03-'04 sedan need to change springs to as high to stock as possible! help
Old Mar 28, 2010 | 02:21 PM
liweih21's Avatar
Hi,
my '03 g35 sedan has the current setup- 2006 coupe's front and rear shocks/struts with 2006 coupe's revised springs front rear 342/427, everything else is stock, oem sports wheels of 215/55/17.
Since is quite hard to find those '03-'04 sedan sport springs, if I only want to change the springs, back to as high as possible, what would you suggest, I do not want to get the non sport '03 springs with the soft rate.
I look into after market sedan springs that drops like 1 inch all around that would work?
also I think someone have to update the specs in some sheets. Compare of a '03 g35 sedan with oem non sports suspension (shocks+springs) was like 3-4 inches taller than put on '06 coupe's suspension.
please help
-Li-Wei
Old Mar 28, 2010 | 05:28 PM
NFSP G35's Avatar
? = 2B || !2B
That post gave me a headache. Please state your questions in a more succinct way.
Did you get rid of your old springs or what?
Old Mar 28, 2010 | 06:22 PM
OCG35's Avatar
I have OEM non-sport suspension if you want it cheap... springs have very low miles (less than 10K), struts have maybe 30K...
Old Mar 28, 2010 | 09:34 PM
liweih21's Avatar
The other way I can do it is just the Sedan's sport suspension springs only.
Old Mar 28, 2010 | 10:50 PM
Swivel's Avatar
Moderator
So you want a softer spring with either a stock ride height or very slight drop, right? Since the coupe springs you have on now have given you only about a 1/2" drop your easiest route might be to replace the rear springs with some base coupe springs since they are not as stiff as the sport coupe springs you have. And it may seem like it to you, but unless something is really wrong, no way is there 3-4" difference in ride height from sedan sport to coupe springs.
I'm not sure what aftermarket springs will give you little/no drop and a near stock ride height.
Or, as you say, to return to sedan sport springs in which case you should put a WTB (want to buy) thread in the marketplace for sedan sport springs.
Old Mar 29, 2010 | 01:53 AM
AARONHL's Avatar
PM mcaron, he has 04 sport springs...
Old Mar 29, 2010 | 07:28 PM
liweih21's Avatar
can anyone verify part# 56210-CM40D is rear springs from 2006 g35 sedan sport ?
Old Mar 29, 2010 | 08:07 PM
813G-WHiP's Avatar
i have 2005 oem sport suspension
Old Mar 29, 2010 | 08:16 PM
olopez's Avatar
I have an 06 non sport suspension
Old Mar 29, 2010 | 08:50 PM
brandon1978's Avatar
I think you mean rear shock part#.
Old Mar 29, 2010 | 09:33 PM
gshock's Avatar
go low!
Old Mar 29, 2010 | 09:54 PM
813G-WHiP's Avatar
low is better!! my splash guard is 6'' or less from the ground..
Old Mar 29, 2010 | 09:55 PM
nlallen141's Avatar
Not that you dont already have enough suspension offers....
but i have 04 X springs and im not too far (AZ)
Old Mar 30, 2010 | 03:34 AM
ray1370's Avatar
Hi,
please help
-Li-Wei
Having a hard time trying to understand your situation here... I just put on 06 coupe non-sports springs+shocks, I noticed the rear is lower than I expected but not by 3-4 inches. Can you post some pics to show us?
Jusseth
Sep 13, 2020 12:25 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
