The sunroof on my 2004 G35 is stuck in the tilt up position...Any ideas???
SubscribeThe sunroof on my 04 G35 Sedan is stuck in the tilt up position.
The sunroof switch and motor appear to be working fine as I can hear the motor running when i press the button to open or close (tilt up/tilt down) the sunroof. It sounds like the connection between the motor and mechanism used to open/close the sunroof is disengaged/broken. Now I can hear a new noise that repeats every 1-2 seconds. It sounds like something is dragging or rubbing.
Any idea what might have happened or how to fix it?
brobably a belt or whatever way the motor is connected broke or slipped off.
i have a bad feeling that you will need to drop the headliner to get to the mechanism
