View Poll Results: Which Company
Voters: 2. You may not vote on this poll
Factory Spray Paint
Factory Spray Paint
Anyone have experience with either of these companies??? I'm Not sure which one I should order from for a car project. Paintworld or Paintscratch
http://www.paintscratch.com/
http://www.paintworldinc.com/
hey i used paint scratch before on my g and didnt like it at all didnt even match was more white then the color my g is pearl white code QX1....got exact same code from paint scratch bt didnt match....
i havent used either company... BUT---If you have a "pearl" color they are very hard to match, this is even when spraying from a satajet gun..There are many variables in getting Pearl paint to match 100%...
yeah thats true..
the silver with metalic in the paint should match much better than a pearl, just match you paint code. i would try a touch up spot on a practice panel(not on the car) and paint it, then let it cure(dry) and then reapply a 2nd coat and let cure to see if it will match.. If matches to your color, then go for it.. Are you touching up on Metal or plastic? how big of spot or area?
