Educate the noob - what are some "must-do" mods for the G35?
Old Apr 27, 2010 | 04:39 PM
  #31
GreatDane001's Avatar
^^ if I was to do either of those it would be a TT setup.
Old Apr 27, 2010 | 04:44 PM
  #32
Swivel's Avatar
Moderator
Drop, wheels, sways, intake, exhaust. Okay screw it, just change everything! haha!
Old Apr 27, 2010 | 04:48 PM
  #33
Jeff92se's Avatar
Red Card Crew
I'd do a LS2 swap.
Old Apr 27, 2010 | 04:51 PM
  #34
My other car is a small-block V8 (5.7L) so if the G was to be modded seriously like this, it would be F.I. At 400 HP, the LS2 should be a blast in a car this size but TTs probably add equal power or more (no idea) and you can "un-do" the mod and sell the turbos if you want to go back to stock.
Old Apr 27, 2010 | 04:56 PM
  #35
Jeff92se's Avatar
Red Card Crew
At 400hp, the VQ is at it's limits. A 400hp/400ft lbs torque LS2 is at it's stock hp. It should be good for another 50hp na? Add a magnuson and it's up to 650hp w/o breaking a sweat?
I'd do this to my sedan. At this point my 03 sedan's resale is practically nil.
Old Apr 27, 2010 | 05:00 PM
  #36
Yeah add a nice sized cam and some heads to the LS2 and you should pick up 100 HP with a tune fairly easily. Those engines love mods. Of course you can then supercharge the LS2 and it's a totally different ball-game and you'll likely need new axles, new transmission and other parts to avoid destroying the G the first time you go WOT haha
I have a little more than 100 RWHP to go before my transmission needs an upgrade in my Magnum but I'm done modding that car.
The G should get some minor stuff but more than likely no serious engine mods for years to come.
Old Apr 27, 2010 | 05:05 PM
  #37
Blue Dream's Avatar
I drove ttrank's car solo
I think ttrank would disagree with you. I understand his motor is seriously built but it's still a VQ.
Old Apr 27, 2010 | 05:06 PM
  #38
Jeff92se's Avatar
Red Card Crew
If swap a LS2, you're either going with the AOD auto or the T56 5-sp.
Old Apr 27, 2010 | 05:08 PM
  #39
Jeff92se's Avatar
Red Card Crew
It's about at it's limits stock. That's the context we are having this discussion. Unless you want to add built LS2 motors.
Old Apr 27, 2010 | 05:14 PM
  #40
Blue Dream's Avatar
Understood.....
Old Apr 27, 2010 | 05:15 PM
  #41
Swivel's Avatar
Moderator
I'd do a LS2 swap.
Waiting.
Still waiting.
I guess it depends how much effort you want to go to and what your power goals are. 400 reliable whp is pretty realistic for 5 grand (local guy is doing kits, dyno proven) and a weekend's work...for someone who knows what he's doing, not me, LOL!
A V8 swap seems pretty major, though I haven't looked into it at all. Plus a quick search tells me the Ls is about 130lbs heavier. Would mess with the handling, IMO.
Old Apr 27, 2010 | 05:19 PM
  #42
Jeff92se's Avatar
Red Card Crew
It's not 130lbs heavier than a VQ35 with a set of turbos, intercooler and all the extra piping.
The other issue is the ecu hacks we doggy doors have to do with any major engine crap.
The LS motor would run on it's own ecu while all the BCM functions would work off the G ecu.
Old Apr 27, 2010 | 05:23 PM
  #43
Swivel's Avatar
Moderator
Good point, shipping weight of a JWT BB530 TT kit is 150lbs.
Old Apr 27, 2010 | 05:58 PM
  #44
Sceptor's Avatar
My friend used to have a g35 coupe supercharged with the 400hp/tq. Anytime he'd floor it in first OR second he'd go sideways and it was less then 60 degrees outside especially
Old Apr 27, 2010 | 06:02 PM
  #45
Jeff92se's Avatar
Red Card Crew
60 seconds? Is that hot?
