Caution!!!! 3 wheel studs snapped today!!
Old Apr 27, 2010 | 01:51 AM
sterling_g35's Avatar
I don't know how it happened, but 3 wheel studs on my right rear rim snapped off today. I'm lucky the wheel didn't come loose. It's being held on by the 2 remaining studs. I'll try to take some pictures tomorrow. I had it towed to the dealer, so we'll see what happens tomorrow. I haven't done anything, or had anything done to the wheels. The last time the rims were off the car was when the dealership rotated my tires a few months ago.
The tow truck driver said it looks like an impact gun had been too aggressive on the nuts and fractured the studs. I just went out of warranty, so I'm gonna push for a good-will warranty claim.
Has anyone ever had this happen???
Old Apr 27, 2010 | 02:06 AM
350GT-R's Avatar
stuff like this happens all the time. you can just replace it yourself. i go through so many of studs because i over tighten it or someone else in a shop does. cost like a few cents in the auto store and just time to hammer them out and put back in. took me about 15 minutes to replaces 3 of my studs for my rear.
Old Apr 27, 2010 | 02:08 AM
SCIONMIKE's Avatar
actua;;y a;; they are is 1.03 at autozone
Old Apr 27, 2010 | 02:12 AM
350GT-R's Avatar
or i can write something really quick.
take off your wheel. take off your caliper, i think it's 2) 17 bolt and it comes right off. then take of your rotor. look at which 3 stud is broken. grab a hammer and bang those 3 out, be careful not to bang the other ones incase you damage the good studs. grab the studs you bought and put them in. find a washer that fits, but make sure the washer is about half an inch thick. put your lug on it and use an impact gun to tighten them. after your done with the studs just put your rotor and caliper back on and tighten everything and bam your done. lol ^o^ but dont forget, the best way to take the lugs off next time, soak it with wd-40, because sometime you over tighten them it sooner or later jams right in.
Old Apr 27, 2010 | 02:13 AM
SCIONMIKE's Avatar
wow i lost 4
Old Apr 27, 2010 | 02:21 AM
SCIONMIKE's Avatar
just fixed like 3 sides last wk bout 15 bux i spent and about 2hrs.
Old Apr 27, 2010 | 02:24 AM
350GT-R's Avatar
one time i had one one stud on one side of my wheel. lol it was a total of 10 studs in one day. i was like forget it, im breaking all of them. bought 20 studs, got rid of all the old ones and just replaced them. so fa the oem ones are alot stronger then the ones you buy from autozones or pepboys. but here is a write up. dont let the dealership charge you for simple stuff like this. http://www.my350z.com/forum/body-int...e-of-pics.html
Old Apr 27, 2010 | 08:33 AM
DivZero's Avatar
Proper bolt technique is to replace all of the studs at one time. Because this is a highly sensitive component in regard to torque, all studs should be replaced at the same time so even clamping load is attained.
BTW, I would be getting new studs from the deal for free (and put them on myself) if that was the last place I had my wheels removed/installed.
Old Apr 27, 2010 | 08:44 AM
blazeplacid's Avatar
sounds like a shop or someone who last put the tires back on, tightened the lugs nuts to tight
most dont use a torque wrench....which I never have for lug nuts either...
Old Apr 27, 2010 | 10:29 AM
Tollboothwilley's Avatar
DO NOT OVER TIGHTEN LUG NUTS
This is one of the biggest reasons that people experience brake problems, ie: warping of the rotors.
You should always have your brakes tightened evenly. This is the reason you SHOULD use a torque wrench.
I dont see how anybody could break these regularly!
Old Apr 27, 2010 | 10:35 AM
kvangil's Avatar
LOL. +1. Some of you guys make it sound like a normal everyday occurrence to brake wheel studs. I've been driving for almost 20 years, and never broke a stud.
Old Apr 27, 2010 | 10:38 AM
RADIOGUY21's Avatar
sounds like the dealership overtightened your lug nuts when they rotated the tires. They only need to be torqued to about 80 lb/ft. I would complain to them about it and have the other wheels checked for proper torque.
Old Apr 27, 2010 | 10:42 AM
JIle342's Avatar
I've never broken one either (knock on wood) but I have been told that you should change all of them at the same time.. broken or not
Old Apr 27, 2010 | 03:24 PM
SCIONMIKE's Avatar
Thx for the info
Old Apr 27, 2010 | 05:52 PM
Sceptor's Avatar
prob not a big deal to go up the street to a local garage and ask the people to retorque your bolts just to get it done right
