Anyone seen this?
Old Sep 24, 2004 | 11:30 AM
sickpig's Avatar
Re: Anyone seen this?
I just had my rotors and pads replaced last week. 20200 miles. The car is a 2003 with an in service date of 6/02. That gives me just 9 more months of warranty if the ones they put in are as crappy as the originals. I just looked up the cost of rotors and pads for a sport equipped sedan at Everything Nissan.com. $1157.30 for parts only. Figure about $1500.00 or so total.
Now, I know we have great brakes, but... While pads are a wear item and last accordingly a rotor should last FAR longer than 20,000 miles! Should last four times as long. SOMETHING is wrong here. $1500 bucks every 20,000 miles for brakes? No thanks.
Mark
2003 Sedan AT. Ivory Pearl/ Willow
20% tint. Z-tube. Clear Corners w/ PIAA.
Aluminum Pedals
Old Sep 24, 2004 | 04:18 PM
cato's Avatar
SouthernComfort Moderator
Agreed. My front rotors were shot at 14500 miles.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 25, 2004 | 12:13 AM
CookG35's Avatar
Well you can get a PAIR of front rotors from Grubbs for $265. Not sure why everythingnissan is so high.
Old Sep 25, 2004 | 10:29 AM
sickpig's Avatar
Well... Rotor without Sport suspension: $104.52. $209.04 per rair. Rotor with Sport suspension: $518.88! $1037.76 per pair!!! I have no idea why the HUGE difference. The price doesn't change my point though. 20,000 miles on a rotor is crap. Plain and simple. My guess is that it is a material problem from the rotor manufacturer. The wear surface is too soft. I've used cast iron rotors and sintered metal pads on race bikes and had longer rotor life.
Mark
2003 Sedan AT. Sport Aero Ivory Pearl/ Willow
Aluminum Pedals
Old Sep 25, 2004 | 05:13 PM
cpwebb's Avatar
My old car, a Passat blew through rotors in less than 15k miles. The first set was replaced at 10K ! The dealer did not even cover them under warrantee, they blamed my driving style. After installing aftermarket rotors at 40K miles I had no further problems. In retrospect, I think the touchfree carwahes with the high pressure wheel spray had something to do with warping the stock rotors, but like I said, I had no problems with aftermarket parts.
2004.5 Diamond Graphite AT Sedan Premium/Aero/Nav
Old Sep 25, 2004 | 08:10 PM
karlhungus's Avatar
I dont get it. I have 43K on my 03.5 sedan and never had the stock pads or rotors replaced. Just had the tires rotated at Les Schwab and they said I've probably got another 10-15K on the front pads, and a ton left on the rears. You guys must be doing some serious high speed stops to be burning through these pads in less than 20K, or I just got lucky. I dunno, but I'm not complaining about Infiniti brakes to anybody, especially a lawyer looking for a meal ticket.
Old Sep 25, 2004 | 08:59 PM
augie's Avatar
After my warranty I'm going aftermarket. This is so ridiculous having to change brakes and rotors every 7-10k. When I had my 02' maxima, I had to replace the brakes every 10-15k. plus the hubs and bearings were replaced. Nissan just makes crappy brakes I guess.
Old Sep 27, 2004 | 07:08 AM
cato's Avatar
Why would the two different suspensions have different
brake parts? Are the part numbers different between the
non-sport vs. sport suspensions?
Stillen sway bars S/H Sport Tuned Suspension
Old Sep 28, 2004 | 12:49 AM
deadmanincbh's Avatar
I dont think Nissan make crappy brakes since they can stop pretty damn good but its the longevity of the brakes that are sub-par.
That odd that the parts number are different.
Old Sep 28, 2004 | 07:29 AM
cato's Avatar
Been thinking about this.....
Does the Sport option also include different rotors as well
as the different suspension?
Stillen sway bars S/H. Sport Tuned Suspension
Old Sep 28, 2004 | 07:51 AM
alderran's Avatar
Two different dealers told me the only difference was the springs were X% stiffer.
2003.5 5AT Sedan Black/Black Premium/Winter Packages
Old Sep 28, 2004 | 02:15 PM
3point5SE_Auto's Avatar
I have 42k on my 6MT sedan (2003), still have original rotors and I am just barely on my second set of pads. I feel the brakes are fine.
My 2 cents.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
