Problem or normal?
Old May 5, 2010 | 09:33 AM
noogee's Avatar
Problem or normal?
My "new" 2006 G35x will hesitate/vibrate/shudder a little bit while in 5th gear on gentle upgrades and downgrades or when gently accelerating on a level road.
It feels like the car is in too high a gear and is struggling at too low an RPM. If I slap the shifter over into manual mode the transmission downshifts into 4th and the hesitation/vibration/shudder stops.
Also, the car will often upshift into 5th at very low speeds (around 30 mph).
Is that “normal” for this car?
Old May 5, 2010 | 09:43 AM
sloppymax's Avatar
There is an existing TSB for this which calls for the replacement of the valve body in the transmission. I had the same issue and had mine replaced at about 15k miles. ITB07-030 is the bulletin number. Since the VB replacement, I have had no issue and all had increased line pressure compared to the original. I cannot remember the increase off hand but I had it logged with auto enginuity.
Old May 5, 2010 | 09:51 AM
noogee's Avatar
Thx for the info sloppymax.
chinee
Jun 10, 2024 07:48 PM
wonderizm
Sep 24, 2015 03:09 AM
zcherub
Aug 30, 2015 05:04 PM
G35CO
Aug 25, 2015 02:00 PM
Phenomenon9
Aug 9, 2015 01:34 AM
