Spacer Question
Old May 7, 2010 | 08:08 PM
komfortable's Avatar
Spacer Question
Anyone know what spacers would get 17" stockers to fit flush? I'm sure they are huge, but I'm NOT sure how huge that is.
Old May 7, 2010 | 08:47 PM
4D05G35's Avatar
A quick way to find out it to grab a tape measure.
Old May 7, 2010 | 10:54 PM
b2autodesigns's Avatar
20mm Front and 25mm rear will sit flush.
Charles
Old May 7, 2010 | 11:27 PM
NFSP G35's Avatar
? = 2B || !2B
934mm.
J/K
Go grab a tape, shouldn't be very hard.
Post pics when you're done, I've always wondered how the oem wheels would look if they weren't sunk in so bad.
Old May 8, 2010 | 01:41 AM
03GT35R's Avatar
running the oem 5-spoke 17" sports, Installed 25mm rear & 15mm fronts, also have tein S tech's
Old May 8, 2010 | 02:36 AM
socialconflicts's Avatar
im running coupe 18s, and they fit super flush, i was planning on getting spacers but after tossing them in, they dont need it. i really like it
Old May 8, 2010 | 12:09 PM
03GT35R's Avatar
if you run coupe rims 18" or 19's on the sedan most likely you will not need spacers because of the offset of the coupe vs. sedan
Old May 9, 2010 | 05:55 PM
I have the s-tech's also. I think I'm going to go with the 15f/25r setup. For some reason, that just sounds good to me. The car is in the shop (lady side swiped me while i was parked) so after I get it back I'll order, install, photograph, and post for you all.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
