1st to 2nd gear pause
Old Sep 22, 2004 | 08:44 PM
jimmcrae's Avatar
When I really stomp on it after I shift into 2nd gear, there seems to be a pause or hitch in the acceleration, then it picks right up. Is this experienced by anyone else and if so is there a fix. All I have is a ztube and popcharger.
Thanks for your help.
Old Sep 22, 2004 | 09:26 PM
ikSardarG's Avatar
Re: 1st to 2nd gear pause
Not sure if you have a AT or a 6mt, but I think this has been discussed in the past. Most modern cars nowadays have computers that would retard the timing a little to allow for proper shifting and timing/detonation control. On a MT car, I would imagine it helps the VDC system control itself too (to not allow wheelspin)...
On my AT sedan, I know that the timing retards like crazy on the first to second shift... It almost feels like a MT car, when someone floors it, let's off the gas and guns it again in second gear. Sounds cool as hell though - but I am sure it costs bigtime in 1/4 miles runs... On the auto at least...
**** Official PAC Aux Input Dealer!!! ****
SWI-X units available also!
Navi-Conversion Kits at Discounted Pricing
*Authorized AV Electronic Dealer*
Old Sep 22, 2004 | 09:38 PM
FLAG35's Avatar
try it with the VDC turned off. makes a world of difference.
04 6MT sedan, black/willow
Old Sep 23, 2004 | 07:32 AM
Q45tech's Avatar
"computers that would retard the timing a little"
The timing is progressively retarded 20+ degrees just before then slowly comes back after the actual shift.
Whole shift process should take less than a second.......though the acceleration may be reduced for 1.2 seconds usually less depends on temperature.
Old Sep 23, 2004 | 01:54 PM
ikSardarG's Avatar
Q45tech: Thanks for the clarification.
So this is the Manual shift sensation we feel and hear? I'm sure someone driving right next to my sedan under WOT first to second shifts think that I have a MT.... Feels like someone feathers throttle and clutch during the shift.
Old Sep 23, 2004 | 04:32 PM
jimmcrae's Avatar
Yes.. I have a 6mt. So this is normal and I can't do anything but turn off the VDC?
Old Sep 23, 2004 | 04:46 PM
av8r's Avatar
turn off the VDC and then post your findings.
04' Sedan 6MT /Premium/Aero/HuperOptik/XM
Z-Tube / Stillen- Sways, Airbox & Grounding Kit
19x8.5/9.5 Hiros / S-03s 245/40 & 275/35zr19
Tokico D-Specs, 350z H-Techs, Kinetix Camber Kit
Old Sep 24, 2004 | 06:24 AM
jimmcrae's Avatar
turned off VDC and there is a noticeable difference. But it seems like I am fishtailing. Is that normal without VDC? Much faster though.
Old Sep 24, 2004 | 11:36 AM
dbarnes's Avatar
jimmcrae:
Is your car an '03 or an '04 6MT ? The '04's came with a limited slip differential, whereas the early models ('03) did not .
With VDC on (normal), my car bogs hard when I shift from 1st to 2nd at WOT, but with VDC off the limited slip differential hooks up and it gets strong rubber into 2nd, sometimes "fishtailing" a little, as you say.
I also read on another thread a few months ago that you can never really completely shut down the VDC system without pulling the fuse.
Don't know, myself. Anyone ??
Sport Sedan Fan - 2004 6MT Sedan
Sport/Navigation/Premium/Aero; "Invisiguard" Bra, Madico Onyx Tint
Obsidian Black/Graphite & "Titanium"
SHE'S SILVER & BLACK - GO RAIDERS!
Old Sep 24, 2004 | 11:51 AM
SixFive's Avatar
Reset the ECU - procedure are on the DIY board. I have seen this compaint many times and this seems to fix it all the time. The timing should have little impact on shift ET's.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Sep 24, 2004 | 05:35 PM
jimmcrae's Avatar
04 manual trans.
Old Sep 28, 2004 | 12:45 AM
av8r's Avatar
I believe the fishtailing you experience when you "romp" on it is a result of a phenomenon we in the industry call POWER You see, under power and without VDC, your car is a little loose. Loose is FAST and on the edge of out of control (not to quote Days of Thunder or anything hehe). Just don't let it get away from you, and turn the VDC ON in wet conditions.
One question, is this your first rwd car? The reason I ask is because a little fishtailing is normal in all rwd cars and maybe that why it feels a little loose to you. One last remedy is larger rear meats. I can hardly break my rears loose anymore (straight line acceleration)
Kelvin Style006
May 23, 2016 03:47 AM
MrIP35
Oct 25, 2015 11:13 PM
beto4632
Sep 23, 2015 04:28 PM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
