Headlight connector removal
Old May 8, 2010 | 01:32 PM
GraphiteGSdn's Avatar
I feel so dumb asking this question but here goes...
I am attempting to remove my headlights but for the life of me cannot get the connector off. Is the clip on the top side or bottom side? Space is really limited and I have tried over and over and nothing. If anyone has quick method to remove please let me know. Thanks
Old May 8, 2010 | 01:37 PM
socialconflicts's Avatar
i had the same problem before, the clips are on the sides. u should be able to feel them.
Old May 8, 2010 | 01:51 PM
Thanks for the quick reply. On the sides? I don't feel or see any clips on the sides but I do feel something on the bottom side. I'll go look again
Old May 8, 2010 | 01:53 PM
yes, the clips are on the sides they kinda stick out slightly so u should be able to notice it.
Old May 8, 2010 | 02:00 PM
tragedycat's Avatar
The harness clip is in this picture right in front of the blue and red wires. Obviously not a G but it basically looks the same. Stick a flathead screwdriver in between the clip and gently wiggle out the harness. The wire harness side of it is surprisingly small, so make sure when you're pulling you actually have one hand on the wire harness (but NOT on the wire or else you'll rip) and the other hand on the big piece of plastic that it is attached to.
Sometimes if you're not careful both of your hands will be trying to pull apart the piece of plastic, because it's bigger and easier to hold onto, which obviously isn't going to do anything.
Good luck.
Old May 8, 2010 | 02:08 PM
this is from when i replaced mine
hopefully it helps you, read through the replies.
https://g35driver.com/forums/lightin...og-lights.html
Old May 8, 2010 | 03:36 PM
G35Papa's Avatar
If you put a flat head screwdriver actually behind the whole plug, you can pry it off the headlight base and give yourself alot more room to unplug the harness.
Old May 8, 2010 | 06:08 PM
4DGS's Avatar
On the sides??? WTH
Those aren't the clips, they are the sliders.
The clip is on the top, push it in with a screwdriver and pull the two apart.
Old May 11, 2010 | 03:18 PM
Thank you all for your help. I may have explained myself incorrectly, which is why socialconflicts referred to the clips on the sides. I wasn't trying to remove the clips that secure the bulb, rather the connector to the headlight housing itself.
Tragedycat, that's exactly how I imagined the harness clip would look like. It would have been nice had Nissan placed the clip on the top side and not the bottom but it could be worse I suppose. Thanks the pic and the explanation. I will attempt with a short, flat screwdriver and try this again.
I was frustrated and the hot and humid weather where i live wasn't helping so I decided to reassemble. Shooting for success this weekend.
Old May 12, 2010 | 04:56 AM
Blue Dream's Avatar
I drove ttrank's car solo
Let us know how it turns out for you.
Danielek
May 1, 2022 01:28 PM
lil beezy
Lights
Dec 23, 2015 05:25 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
