Gentleman!
Old May 12, 2010 | 11:54 PM
LuXXXz's Avatar
Gentleman!
are tire rods, compression rods and steering/suspension components
same for coupe and sedan?
Old May 13, 2010 | 01:39 AM
DaveB's Avatar
I don't know why they'd be any different. Look here to verify http://www.trademotion.com/partlocat...odel&siteid=55
Old May 13, 2010 | 11:37 AM
416dawn's Avatar
No, they are not.
Even 2WD and 4WD are different.
Coupe ones are same as 350z.
Old May 14, 2010 | 12:16 AM
BuckeyeInMI's Avatar
Tie rods are the same on all RWD's, compression rods are different on Coupes, Sedans, and AWDs. You'll have to be more specific on the suspension parts, because some are the same and some are different.
Old May 14, 2010 | 12:17 AM
4DGS's Avatar
Originally Posted by 416dawn
No, they are not.
4WD what? pathfinder? Get your facts straight before you correct people.
Yes they're all the same. You sure on the X buckeye?? You of all people would know though lol
NVM misread what you said.
Old May 14, 2010 | 11:06 AM
416dawn's Avatar
Sorry, I had no idea that this forum is not strictly for G35.
I meant compression rods for Infiniti G35 2WD/4WD (V35: 2003-2007)
Old May 14, 2010 | 09:17 PM
4DGS's Avatar
^ there is no such thing as a 4wd G.
There is an AWD G....
Old May 14, 2010 | 09:23 PM
thescreensavers's Avatar
Mr.202?
the AWD G Sedan I believe has IRON Comp rods so they are different from the RWD G.
Check the TSB for the comp rods I believe its listed there.
Old May 14, 2010 | 09:42 PM
Mustang5L5's Avatar
....which has "4WD" stamped on all the unique suspension components and the underbody tray.
Some of the front suspension parts on the g35x actually have 4WD cast into them, he lower control arms are one of the parts. The comp rods do not have this cast...but these are different between rwd and awd.
Technically, awd is 4wd. Awd is another term for full time 4wd. When you flip the snow mode switch and lock the diff 50:50, you are now in part time 4wd. A system that can do this automatically and electronically is called awd. It's all semantics.,,but basically the same thing.
Old May 15, 2010 | 02:55 AM
6spSEDANFTW!'s Avatar
ownd.
Old May 15, 2010 | 02:57 AM
Originally Posted by 6spSEDANFTW!
ownd.
You misspelled pwned.
Old May 15, 2010 | 03:03 AM
dman, bcak to mi hookd on foniks tehn....
Old May 15, 2010 | 03:47 AM
4DGS's Avatar
Orly,
explain to me 4wd and awd.
Then I'll tell you why I don't care what's stamped in the suspension.
Old May 15, 2010 | 03:59 AM
yes, yes.... yes.....we all know the difference between awd & 4wd....but i think u forgot to finish reading all of Mustang5L5 post (#9) where he clearly states why he believes in the 4wd stamping, witch in result is a great interpretation. so ur still in the pwnage state of the thread....u cant get off that easy, sorry
Old May 15, 2010 | 04:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
Orly,
I have to agree with the post above. Your period of pwnage hasn't expired yet. Sorry!!
