suspension help guys URGENT URGENT
Old May 14, 2010 | 12:30 PM
LuXXXz's Avatar
hey i seem to found the problem on my car and i dont think its the tire rod ends
i found this piece is moving like crazy on the passanger side there seems to be a bushin inside of it but on the drivers side its moving left and right like crazy and its all loose
here is a pic of it, what is this part called!
or if its possible to get just the bushing for the right side(looking at the pic)
Old May 14, 2010 | 01:19 PM
AARONHL's Avatar
I see about twenty components in the picture, which one is it???
Old May 14, 2010 | 01:23 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
It's the lower control arm. You can replace just the bushing. But the arm isnt that expensive and will leave you with no down time if you replace the whole thing as opposed to taking the arm off and taking it to a shop to have the bushing pressed out and the new one pressed in.
Old May 14, 2010 | 01:58 PM
LuXXXz's Avatar
its circled in blue!
thnx gdup!
do you know where i can get just the bushing?
just one bushing cause everywhere i looked its both!
and how cheap is a control arm cause ive seen for 200
Old May 14, 2010 | 02:08 PM
AARONHL's Avatar
WOW I did not see that...TRY THICK RED NEXT TIME!!! Go to a junkyard and buy that control arm for like $30.
Old May 14, 2010 | 02:23 PM
JOKER's Avatar
CLUB MODERATOR
^you can prolly pick up solid bushings for less than that
Type in "Bushings" in the search and go to town.
I'm sure you can find something on here.
http://www.g35parts.com/G35-Front-Co...r-p/w52991.htm
http://www.g35parts.com/G35-Front-Sh...m-p/w52992.htm
also look in here
http://performanceshock.com/index/ma...336815619a0010
http://www.jscspeed.com/catalog/Niss...initi_G35.html
Old May 14, 2010 | 09:50 PM
AARONHL's Avatar
It would probably be >$30 for a bushing press.
Mry
Mar 3, 2023 01:03 AM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
bTanz
Oct 15, 2015 02:31 PM
Fireman07603
Aug 9, 2015 06:00 PM
keithk831
Aug 2, 2015 09:50 PM
