Check Engine Light???
Old Sep 24, 2004 | 12:53 AM
iLLG35's Avatar
NY G-Squad G Race Driver
Well it hasnt happened in my year of having the car whihc is 15k miles approx (August) or after my mods, i know the light should pop up with test pipes after 1k miles on the car (?) but ive had the exhaust and test pipe's on for over a month and way over 1k miles, i turned off my car then turned it back on and it was still there, then i did an ECU reset and it went away. Now i was driving it not hard but aggressivlely after to see if it would pop on again and it didnt, should i be worried about it and get it checked?? Thanks, Martin..
Martin
2003.5 BS G35
Nismo Aero/Sport Package
0-60 5.4 - 1/4 Mile 14.16 *GTech* and on 19's!!
Old Sep 24, 2004 | 01:12 AM
GurgenPB's Avatar
Re: Check Engine Light???
Hey
My CEL comes on once a week since the installation of the test pipes.... and it was a cat-related code...
NExt time it comes up... don't reset. Get it read with a reader. If you guys have autozone there... they do loan out scanners. When you get the code, if you don't have the shop manual, post 'em and I will look it up. The only way to know for sure
Gurgen
Old Sep 24, 2004 | 07:53 AM
cato's Avatar
SouthernComfort Moderator
This happened to me also. Turned out that I left the gas cap
sitting in the holder instead of putting it back on. Check
the gas cap!
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 24, 2004 | 08:14 AM
PotomacG's Avatar
I set off my SES light when I changed my air filter and moved the car before reconnecting the mass airflow sensor. Doh!!!
ECU reset hasn't made it go away. I'm now waiting for my AutoTap code reader to be shipped. There are dozens and dozens of sensors in the car that can set off the SES light. A while back I paid a Ford dealer $130 to tell me that my wife had left the gas cap off her car once. This is why I believe a code reader is a worthwhile investment. Even if you don't repair the car yourself, it's worth knowing what is wrong with the car befor you take it to a mechanic.
I also feel that spending $20 downloading the service manual from the Infiniti website is the bargain of the century. Everything you ever wanted to know about your car is in the service manual. Good luck.
Old Sep 24, 2004 | 09:12 AM
mark5's Avatar
my gas cap wasn't tight enough, if it's the gas cap it'll go away.
Old Sep 24, 2004 | 10:06 AM
iLLG35's Avatar
Man thanks for the replies guys, well i did get gas before it happened but im 100% posititve i put it on, i'll check it though anyway! Well the light hasn't came back on today after the reset, i just hope that the reset didnt take the light away but i still do have a problem, i doubt i do though, i want to take it to infiniti but i have so much work done what if there's something wrong lol, they'll be like checking off X's on a clipboard of things i voided and be like, :Hey sorry, but your whole car is voided" w/e LOL
Martin
2003.5 BS G35
Old Sep 24, 2004 | 10:38 AM
mark5's Avatar
the gas cap has to be on TIGHT, not off
Old Sep 24, 2004 | 06:00 PM
skeleton_cru's Avatar
Sedan
Check your oil!!! LOL
Old Sep 24, 2004 | 07:47 PM
zimbo's Avatar
You can do the pedal ECU reset procedure to determine what the SES code is. After the car goes into that mode (you have to do the pedal dance first, of course), the SES light blinks 10 times and then it does three sets of blinks with each set of blinks corresponding to one digit (and 10 blinks means 0).
Sorry if that makes no sense. Once you know the code, I can tell you what it means (via the service manual).
--Steve
Old Sep 24, 2004 | 08:40 PM
iLLG35's Avatar
Well id rove it all day and it didnt come back on, ig uess i shouldnt worry then? Zimbo, if i follow ur step, that can actually tell u what the code is? That isnt just for resetting the ecu?? Thanks again guys =)
Martin
2003.5 BS G35
Old Sep 25, 2004 | 01:30 AM
zimbo's Avatar
Yes, the resetting the ECU procedure is the way you tell the code. After the SES light blinks 10 times at the completion of the procedure it will then go dark for a second or two and then do three sets of blink to count out the code.
--Steve
Old Mar 11, 2005 | 12:53 PM
Calgary_G's Avatar
engine light
I installed a K & N 2 nights ago & started the car for 30 seconds without the electrical hooked back up to the intake, and realized it & shut it off. Hooked it back up & now for 2 days engine light still on. I tried 12 hour battery disconnect last night, but still on. ANy suggestions? Thank you
Old Mar 11, 2005 | 01:02 PM
PotomacG's Avatar
My SES light did not go off by itself either. I used AutoTap to reset it. Either take it to the dealer or find someone with a code reader.
There's physically nothing wrong with your car. For some reason the MAS does not reset itself after an ECU reset.
Good luck.
Old Mar 11, 2005 | 01:12 PM
Calgary_G's Avatar
Thanks for that info. I have done the battery disconnect, but have not tried the pedal method??? It is under warranty but too much of a hassel to take in? Maybe just go to an auto store?
Old Mar 11, 2005 | 04:09 PM
jawjaw's Avatar
You need to figure out what the code is before trying to get rid of it. It could be just about anything. I wish car manufactures would stop playing the hidden code game and just tell the driver what is wrong. It seems silly for someone to have to make time to take their car to the dealer when the gas cap is not tight enough. The driver does not know if it is a serious problem or not so CEL's often get ignored.
I don't know if it is the case with Infiniti, but some car manufactures keep their codes a secret so you are forced to take your car to the dealer. Independent shops cannot do a thing about it and are upset.
