G35 Automatic Transmission HP Power Rating??
Old Jun 3, 2010 | 04:34 PM
TwinTurboSedan's Avatar
How much HP can the automatic transmission handle HP/Power wise?
Old Jun 3, 2010 | 05:16 PM
NFSP G35's Avatar
? = 2B || !2B
Stock? Not a lot.
Old Jun 3, 2010 | 09:37 PM
Mustang5L5's Avatar
Isn't it the same one used in the m45 as well?
Old Jun 3, 2010 | 09:44 PM
GOWAD's Avatar
1000 if you have the money
Old Jun 3, 2010 | 11:40 PM
jjyellow's Avatar
stock around 450
Old Jun 3, 2010 | 11:48 PM
DaveB's Avatar
Transmissions are rated in torque capacity and not HP. Any vendor that quotes you that they can modify your tranny to handle Xhp can't be trusted. It's torque that's going to break things. With that said, I believe the JATCO 5AT in the G35 is rated to handle around 325 ft/lbs. The same tranny with heavier components can handle over 400 ft/lbs in the Titan.
Old Jun 3, 2010 | 11:52 PM
NFSP G35's Avatar
? = 2B || !2B
^Does the Frontier AT have heaver components than the G?
Old Jun 4, 2010 | 12:49 AM
Ok. Thanks for the input guys.
Old Jun 4, 2010 | 08:53 AM
GThirty-Kevin's Avatar
Damn that K&N air filter I bought is gonna put me over the limit! I better ride around with my AC on from now on...
Old Jun 5, 2010 | 01:27 AM
KBTOPDOG's Avatar
lmao, did you get a z-tube also.....
Old Jun 5, 2010 | 09:17 AM
G35xTurbo's Avatar
I've heard about the same numbers from a few tuning shops.
Old Jun 5, 2010 | 10:15 AM
GT-ER's Avatar
I put down 360whp and 300lb-ft of torque and it's been running great with only a transgo shift kit. It'll even chirp 3rd gear.
Old Jun 5, 2010 | 11:00 AM
NFSP G35's Avatar
? = 2B || !2B
^How many miles, and how many of those FI?
Old Jun 5, 2010 | 11:33 AM
Tollboothwilley's Avatar
seen lots of 5AT guys running around. Most do fine with a shift kit and Torque Converter for 400 at the wheels. You need to control the gear that you are in when you plan on boosting though. Several guys have burned them up by keeping in D and punching the gas.
Old Jun 5, 2010 | 10:44 PM
GT-ER's Avatar
80K miles total and 5K of those have been FI. I beat the CRAP out of my car though...it sees SEVERAL wot runs every single day and has been to the dyno many times in those 5K miles....lol.
