coupe midpipe install = rattle noise
Old Jun 6, 2010 | 02:14 AM
socialconflicts's Avatar
hey guys, well grant just installed my coupe midpipe and it is making a rattle noise around where it seems to be the Y pipe since i feel the noise is by where my gear shifter is. he did put a rubber thing on before i left so it cleared out the noise but it seems it fell off.
grant told me he needs to find a part to put in that area, is there a temporary fix.. thing rattles like hell when i start the car... i feel like im on my sentra lol
and does anyone know where exactly the noise is coming from?
thanks
Old Jun 6, 2010 | 02:25 AM
Jairen's Avatar
Are you missing any hangers? There is only 1 hanger to install and 4 bolts.
Old Jun 6, 2010 | 02:37 AM
i doubt it, grant installed it and he seems to be familiar with a lot of the bolt ons..
grant said he needs to get a better piece that will wrap around a metal piece.. to me it seems as something could be loose but then again the midpipe coupe is much smaller so it does reach less than the sedan midpipe.
Old Jun 6, 2010 | 02:46 AM
geesahtee5's Avatar
isnt there a heat shield that needs to be slightly bent?
Old Jun 6, 2010 | 02:50 AM
i dont know... he said he needs to find a part that will wrap around the metal piece.. maybe instead of bending he is going to add a piece? i just want a temp fix for now
Old Jun 6, 2010 | 06:57 AM
Exe G's Avatar
i had a rattle when I had the coupe midpipe on my car too. From my experience, the coupe midpipe has a little bend/curve that is slightly different than the sedan's midpipe. That part sits too close to a little brace that I assume might be to block the exhaust from coming up and hitting the drive shaft in an accident. On my car, it only rattled on bumpy roads, but i guess its worse on your car.
Old Jun 6, 2010 | 08:07 PM
Pmpjuce06's Avatar
+1 same issue happened to me. take it back and have them look to make sure that it is not touching anything to make it vibrate
Old Jun 6, 2010 | 09:25 PM
azt108's Avatar
there is a bracket that also needs to be removed as well as the heat sheild that needs to be bent.
Old Jun 6, 2010 | 09:32 PM
04G35NYC's Avatar
You just have to push the heat shield upward not to much and you will be ok, i did this 3 years ago you should be fine when you work on that heat shield.
Old Jun 6, 2010 | 10:33 PM
Ludafish's Avatar
+1 I had this same issue. I did not want to remove the brace so I went with a Sedan 05 midpipe and couldnt be happier with the set up. GL but I am SURE it is hitting the brace below the driveshaft. I thought of covering it with something but it is not worth the trouble and couldnt think of something that would be perminant and stay
Old Jun 7, 2010 | 06:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
^^ I wondered how long it would take you to find this thread. I guess you're not crazy and your CM isn't the bastard child we thought it was.
Old Jun 10, 2010 | 11:16 PM
shawnzer's Avatar
does anyone know if a 05 coupe midpipe will fit on a 04 sedan?
Old Jun 11, 2010 | 03:30 AM
it will, just it may rattle like mine, grant aka gdup put a plastic/rubber tube and connected both hooks that go outside and ever since has been quiet.. only in heavy bumps do i hear a little movement. but no rattle.
Old Jun 11, 2010 | 10:38 AM
Ludafish's Avatar
Thats what I switched to from the coupe middy and couldn't be happier with the choice. maaaaaaaybe a lil vibration (most likely from the HR Y-pipe) but no rattle
rezendvous420
May 31, 2020 01:26 PM
Joshua615
Aug 31, 2015 12:29 AM
kinetek
Aug 3, 2015 04:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
