ABS kicking in @ wrong time?!?!?!
Old Jun 12, 2010 | 04:01 PM
CG4DR's Avatar
I recently installed spc front camber kit, I am now noticing my ABS pump kicking on under normal braking. I can also feel the ABS action in the pedal. Just wondering if it has to do with the ABS being to far spaced out or if maybe something else with the brakes system??
Old Jun 12, 2010 | 04:17 PM
Blue Dream's Avatar
I drove ttrank's car solo
Did you follow the instructions and install all of the spacers and the new bracket for the sensor?
Old Jun 12, 2010 | 04:27 PM
CG4DR's Avatar
yeah.. it says 2 spacers.. i used 2 for each side made sure the assembly spun freely.. all spacers including caliper were used and i even topped off brake fluid
Old Jun 12, 2010 | 06:24 PM
CG4DR's Avatar
went out and redid the spacers for the sensors.. right i took all out and the left i had to add 2
Old Jun 13, 2010 | 01:52 PM
CG4DR's Avatar
Still doing it but not as bad..
