!!Drive Belt Issue-Please Help!!!
Old Jun 12, 2010 | 06:44 PM
GreenPenguin's Avatar
Angry !!Drive Belt Issue-Please Help!!!
So, I finally got around to buying new drive belts for the ac compressor and power steering pulleys. $66.36 for the two from Norris Nissan(same as 350z belts). Anyway, after taking the 101 bolts off for the undercarriage cover and attempting to loosen the tensioner pulley, I hit a snag- neither of the tension bolts are budging. Whether I turn em right or left I get nothing. The service manual calls for 26 pounds torque for them so I can't understand why someone would have torqued them so drastically. I was tugging so hard that my ratchet slipped and I stripped the AC tensioner bolt. Did anyone else have this type of issue? And where do I go from here?
Old Jun 12, 2010 | 06:58 PM
Texasscout's Avatar
They may have been torqued correctly but have become stuck due to corrosion (water, road salt, etc). You should first get a good penetrating oil (Aerokroil is the best but hard to find) and soak both bolts down good. Next get a good 6 point socket of the correct size (don't try to get by with SAE sockets on Metric bolts) and try it again. If you strip that, you can try a bolt remover socket from SEARS that might work.
I have backed off many a stripped bolt with a good pair of "ViceGrip" pliers. It's ugly but it get's the job done.
Old Jun 12, 2010 | 07:00 PM
Blue Dream's Avatar
I drove ttrank's car solo
A friend of mine and I replaced our belts a few months ago and had no issues. If you're having a hard time with bolts, I would suggest using a breaker bar instead of a ratchet to get them started. You will probably need to go to a parts store and get a bolt extractor kit, it will have specially grooved sockets that will grip the stripped head and give you leverage to get it out. Make sure you pick up a replacement bolt while you're there.
Old Jun 12, 2010 | 07:06 PM
Will WD40 or PB Blaster work the same? Also, I tried both a 9/16 and 14mm socket with the 9/16 seeming to make a better fit. I began to wonder what would happen if I just lowered the tensioner pulley and replaced the old belt with the new... Any ideas?
Old Jun 13, 2010 | 01:06 AM
bythabay's Avatar
did you remember to loosen the idler pulley nuts? The tension adjusting screws won't move until those nuts are loose
Old Jun 13, 2010 | 11:29 AM
DaveB's Avatar
Bingo. Those tension bolts won't loosen until you break the pulley nuts loose.
Old Jun 13, 2010 | 11:52 AM
Last night I went to Sears and got a breaker bar and a stripped bolt remover per TexasScouts advice. Sure enough the pulley bolt came right off. I changed my belts just in time by the looks of my old ones; they had several deep cracks in em. I'm glad they didn't explode on me and cause other issues. Thanks eveyone!
Old Jun 13, 2010 | 12:52 PM
tonke73's Avatar
I use a 10 inch pipe that slides over my ratchet as a breaker bar. Its better than the hammer and ratchet approach. Glad to hear you got the bolt off.
Old Jun 13, 2010 | 02:46 PM
Blue Dream's Avatar
One of the reasons I love this forum. I learned something new today. Thanks guys!
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Wayne9011
Aug 17, 2015 01:24 AM
D1dphresh
Aug 7, 2015 06:10 PM
wuppiedog
Aug 7, 2015 11:16 AM
Wayne9011
Jul 27, 2015 11:25 AM
