Anyway i can fix this?
Old Jun 19, 2010 | 09:56 PM
naughty240's Avatar
Those wheels look good Blue Dream.
Old Jun 19, 2010 | 10:05 PM
TurTLe*'s Avatar
Originally Posted by Wannabe6MT
Running Z/G coupe setup with coupe 19s on Falken FK452s that i put on almost 20k miles ago...
Shocks should have 50-60k on them, and they feel fine. Just feels like it may be my big wheels and less than perfect tires.
you assuming your shocks feel fine is not a way to look at this.
19's should be the biggest reason pair that up with some low pro summer tires that have like 33% life on them. 20k is a lot of them.
you also have to factor in your pairing up a suspension that wasn't designed for the car. you said Z/G setup, i assume that means springs and shock/struts...
Best and fastest way right now is put on your winter setup and drive down the same road to see if its your suspension doing more of the harsh feel or the wheels.
Old Jun 20, 2010 | 12:06 AM
Wannabe6MT's Avatar
-MN G Crew-
When i drove my car with the 17s on, it felt so much smoother. Like the steering wheel turned a lot more nicely, and it absorbed the bumps better, but i attribute that to the fact that there is so much more side wall.
I might swap em out next week and drive around a bit again, but im fairly sure its the wheels.
Old Jun 20, 2010 | 01:33 AM
G35xChicago's Avatar
With my current susp setup, i cant tell much difference between the 19s and 17s that i use in the winter. Like Dave said, its definately the midwest roads, they are horrible. When its smooth rode, i feel like im in a lexus.
Old Jun 20, 2010 | 02:29 AM
usafdarkhorse's Avatar
You're just going to want a thick sidewall, higher aspect ratio. Go with the smaller diameter wheels with higher aspect. SUV owners realize they made a poor decision when they throw on 22s with really low profiles and the ride is absolutely horrific.
Old Jun 20, 2010 | 05:17 AM
thescreensavers's Avatar
Mr.202?
What PSI you running your tires at?
Old Jun 20, 2010 | 06:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Thanks. I like the overall look of the coupe 19s I'm running now better, but the 18s have a better finish IMO.
Old Jun 20, 2010 | 10:08 PM
G35Papa's Avatar
haha ride like crap?
No, I actually like how it rides but its more on the stiff side (that's what she said ). I like how it responds in corners and has less give when stepping on the gas so there's less wasted energy on compression. Sounds like you want something that is more comfy and cushiony. Nothing wrong with that. That's what I liked about the G when I first bought it.
Old Jun 21, 2010 | 12:09 AM
DaveB's Avatar
Like others said, 20K miles on high performance rubber means the tires are getting close to dead. Performance tires get loud, grainy, and stiff once they surpass about 60 to 70% of their life. You really can't expect more than 20 to 25K miles out of a decent set of high performance rubber.
The shorter sidewalls aren't doing you any favors nor the much wider contact patch. The reason the 17s turn so much easier is because the contact patch is so much narrower.
I recently drove a friends bone stock 04 non-sport sedan and it was shocking the difference in ride, quietness, and handling. Granted my 18" PZeros are right near their operational life and roar on asphalt surfaces, this stock G felt like a Camry in comparison. It was extremely quiet, road softly, and handled like a wet pork chop.
Old Jun 21, 2010 | 12:29 AM
dukehotty's Avatar
Lincoln Towncar will offer you a very, very smooth and quiet ride. Bench seats too!
Old Jun 21, 2010 | 01:02 AM
Wannabe6MT's Avatar
-MN G Crew-
I just want my car to not knock the GPS off my dash every time i hit a crack in the road.
As any other MN person can attest, MN has no fun roads, and most of my driving is around town or on the interstate. And as i'v said before as well, my car handles like a wallowing dinosaur around corners anyways so the only thing im gaining with my dropped stance is appearance. And that i dont really care a ton about. I just want to enjoy the car and the bone shattering ride just isn't doing it for me anymore like it once did. I'v also been thinking about ditching the coupe mid and HR y-pipe to quiet it up a bit...
Bleh. Im such an old man.
I'v been thinking about this topic every time i'v jumped in my car. Im almost thinking, screw it and buy some new tires, but im just so afraid that i'll drop 7 bills on some new tires and have it still ride like complete ****. That and i need compression rods, an alignment, tranny flush, front bumper repaint, etc. It's a good thing i have a lot of jobs coming up. My car decided to be a money pit at the worst possible time...
Old Jun 21, 2010 | 01:09 AM
NFSP G35's Avatar
? = 2B || !2B
You are an old man... so if you move to FL it's either Boca or Sarasota for you
Cracks me up that you refer to your ride as "bone shattering" You should ride in my cousin's 350Z!!
I trust you'll lmk if you really do decide to get rid of exhaust components
Old Jun 21, 2010 | 01:15 AM
Wannabe6MT's Avatar
-MN G Crew-
Im moving to Jupiter, buying a Cadillac DTS, and living the life...
Old Jun 21, 2010 | 01:22 AM
NFSP G35's Avatar
? = 2B || !2B
I'm almost in Jupiter right now... Stuart
Old Jun 21, 2010 | 01:24 AM
  #30
Wannabe6MT's Avatar
-MN G Crew-
We stayed in Jupiter, it was quite old lol
BTW, anyone have a spare door laying around? I REALLY need this bracket (has to be from a sedan)
The screw goes through the hole in the top of the arm rest
