19x10 fit ??? rays g games
Old Jun 29, 2010 | 07:24 AM
Rodrigo's Avatar
I am looking to get a new set of wheels and this guy is local , i have seen some sedans run crazy offsets but never a 19x10 up front which is my main concern ,
my fenders are rolled and im lowered on
revised springs and tokico blues for a 350z.
they are nice tho , check them out . 19x10 all around +28
i would run a 255 40 19 all around.
any input is greatly appreciated
http://my350z.com/forum/wheels-tires...9x10-28et.html
Old Jun 29, 2010 | 08:35 AM
Z's G's Avatar
I am running 20x10 up front with a 30 offset with no problems. Tires are 245 35 20. Im also lowered on 350z H&R springs. Right now I just have natural camber and will probably add a spacer to get down around 20 offset.
Old Jun 29, 2010 | 09:01 AM
FlyingLumpia's Avatar
^^ Pics or it didn't happen ^^
Old Jun 29, 2010 | 09:06 AM
SN00P's Avatar
CLUB MODERATOR
curious to see some pictures myself not may many or if any are running a 19x10 or 20x10 in the front with those kind of off sets .. i can see 9-9.5 up front and wiuth 350z H&R springs i no will drop you a good amount .. how much camber are you running in the front -4º or more
Old Jun 29, 2010 | 09:28 AM
Matzo Ball's Avatar
20x10? Pics or gtfo. You running Pisto camber?
Old Jun 29, 2010 | 09:29 AM
SN00P's Avatar
CLUB MODERATOR
hes running pisto camber in the front
Old Jun 29, 2010 | 09:32 AM
SN00P's Avatar
CLUB MODERATOR
[QUOTE]
***NOTE***
All 4 wheels are 19x10 +28et all around.
2 wheels are in Gloss Black finish and 2 wheels are Chrome silver.
I was going to rock silver on driver side and black on pass.
The New owner can have 2 of them refinish to silver or black./[QUOTE]
in the picture 2 of the wheels are black and 2 wheels are silver .... hows this going to work for you
your going to spend extra money on top of this ... i would find a complete set somewhere already painted and different size
Old Jun 29, 2010 | 10:10 AM
Johnnyone's Avatar
Marcus will probably chime in on this later and provide a lil more detail cause he’s s a wheel guru.
But IMO I think the 255/40 is going to be too much meat. You are going to need at least a 35 series tire and maybe 235/245’s instead of 255’s up front. And I would think you need an aggressive drop or it’s not going to look right.
Old Jun 29, 2010 | 10:24 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You can fit it, but it wont look good with only a 1" drop. You need to be dropped atleast 2" and run a 245/35 tire all around for it to look good.
Old Jun 29, 2010 | 10:38 AM
Rodrigo's Avatar
times 2 on the pics of this .
[QUOTE=g35snoop;5195937][QUOTE]
***NOTE***
I will run silver on one side black on the other , i thought of a two faced look for a while , and sudddenly these came up and they are local.
255 on a 10 inch wide wheel is a strech the reason behind the 40 series is because of the damm miami and fort lauderdale roads and construction , gives me a little more peace of mind.
another plus is that i can rotate the tires for a change .
show some me some pics if anyone is running a 19x10 , id like to see for reference.
Old Jun 29, 2010 | 10:45 AM
NorthSideRacing's Avatar
Pics or Ban.....
Old Jun 29, 2010 | 11:00 AM
CandlestickPark's Avatar
ill Sedan
Nah, Grant is the real wheel guru, gtrfever and donpisto are a couple of others. I just know my Sedan widths/offsets and tire sizes because I've run a few setups and study what everyone else has done.
Old Jun 29, 2010 | 11:42 AM
Rodrigo's Avatar
whats your take on this Marcus
Old Jun 29, 2010 | 12:07 PM
ill Sedan
255/40 is too large of a tire for this setup. I would go with a 245/35. You are going to have to be low to pull this off, a 1" drop won't cut it IMO. You need to be lowered at least 2-2.5".
You are going to need a fender roll/pull up front for sure. I'm running 8.5 +15 at the moment which is 6mm less agressive than your proposed setup. When I was lowered 2.5" I would barely rub with a 245/35. Now that I'm lowered ~3.5" up front it rubs like crazy when I turn.
The rears are 2mm less agressive than my current setup (9.5 +20) so a flat roll will be fine as long as your camber is dialed in.
Old Jun 29, 2010 | 12:11 PM
The Stimulation's Avatar
Lol @ pisto camber. 20x10 will be doable. I test fitted 20x10.5's up front with a 0 offset. Didn't drive, but it seemed like everything cleared. But you would need a ton of negative camber and a pretty aggressive stretch to pull it off.
