Need A Little help, a/c blow hot air and radio works fine.
Old Jul 14, 2010 | 12:59 PM
gambit2083's Avatar
So....
my a/c blows hot air not matter what setting I put it on. It was working when I got the car back in feb but really havent used it till now, radio works fine too no pproblems at all. After doing a search I checked the lines and I have no leaks (intake) and the only (other problems) that I have in the car is that the engine bay fan (nearest to the ac line) dosen't turn on at all and I have the ABS, SLIP, and VDC light on. Brackes are fine, pads are fine, and fliud is fine,rotors are old though. Took it to tire plus and after them having it for 2 hours, they couldn't find the problem either. Nearest dearer is not close at all, any ideas
Thanks
Old Jul 14, 2010 | 01:02 PM
gambit2083's Avatar
oh yeah, ther is freon level is not low at all, that was verifed and checked by them.
Old Jul 14, 2010 | 04:17 PM
Mustang5L5's Avatar
Blend door issue?
turn the a/c on and wait a few mins and then feel the lines under the hood...high side should be hot and low side should feel ice cold. If not, you have an ac prob.
if it is cold, then you have a blend door issue. Can you adjust the heat at all?
Old Jul 14, 2010 | 04:31 PM
gambit2083's Avatar
Originally Posted by Mustang5L5
Blend door issue?
...checked.... both are hot as hell
arora_g35
Apr 16, 2026 02:52 PM
champppy
Mar 31, 2020 12:25 PM
kd03g99
Jul 30, 2015 11:24 AM
Rehman2009
Jul 27, 2015 03:23 AM
justgotg35
Jul 19, 2015 12:33 PM
