need help on wheel sizing
Old Jul 16, 2010 | 08:17 PM
Gorg3ou5's Avatar
would these fit my 03 g35 sedan.
front:
Offset:+30
Centerbore: 73.1mm
rear:
Offset:+25
Centerbore: 73.1mm 73.1mm
will it stick out?
what tire size would you folks reccomend?
and any pics of a 03 sedan with these sizes.
thanks g35drivers!
Old Jul 16, 2010 | 08:18 PM
Get_some35's Avatar
depends on how low you are
Old Jul 16, 2010 | 08:20 PM
Gorg3ou5's Avatar
car ispretty low...
would i need to raise it?
Old Jul 16, 2010 | 11:39 PM
marrero's Avatar
loves it.....no, you don't need to raise it up.
Old Jul 17, 2010 | 01:18 AM
xxxxxxxxxx's Avatar
wat rims are those
Old Jul 17, 2010 | 03:12 AM
asma123's Avatar
I don't know but that g35 looks hella sexy. those rims def compliment it and the height is just perfect.
Old Jul 17, 2010 | 06:37 AM
Gorg3ou5's Avatar
thanks guys! what series tires you guys would prefer?
---those are stock q/fx rims on my ride right now painted graphite..FIRST TO DO SO
Old Jul 17, 2010 | 01:25 PM
Get_some35's Avatar
hmm rears are pretty aggressive youd need a fender roll and id run 235/40
but for the front its pretty weak id run a 215/40 and a 25mm spacer and fender roll
https://g35driver.com/forums/media-s...tch-sedan.html
but you should look here for fitment stuff
Old Jul 17, 2010 | 08:48 PM
Gorg3ou5's Avatar
thanks bro! will those tire sizes be stretched much? also will the rear sizes be flushed?
Old Jul 17, 2010 | 11:40 PM
Get_some35's Avatar
not that much. idk if theyre on but to get an idea check out tyrestretch.com rears should be close to flush. heres my old set up. rear is 19x10 +24 235/35
Old Jul 18, 2010 | 08:01 AM
Gorg3ou5's Avatar
i see, maybe a 20 mil or even a 15 spacer would help?
what size is ur fronts
Old Jul 18, 2010 | 10:11 AM
Get_some35's Avatar
fronts on that pic is 19x9 +24 225/35. and yeah spacers would help but i think wider wheels with lower offset would be best
Old Jul 22, 2010 | 05:00 AM
Gorg3ou5's Avatar
i guess ill run 215/35 and 225/35...can do?
Old Jul 22, 2010 | 07:05 AM
Blue Dream's Avatar
I drove ttrank's car solo
Make sure you get the hub centric rings that convert from 66.1 to 73.1. Some aftermarket wheels come with them and some do not.
Old Jul 22, 2010 | 11:26 AM
Get_some35's Avatar
yeah but i dont think the stretches would match. the 225 on the 10 would be a nice stretch while the 215 on the 8.5 would be pretty mild. id do 205/35 on the 8.5
