well, my first problem in 4 years!!!
Old Jul 25, 2010 | 06:48 PM
jayflyxx's Avatar
my 05 G35x has developed a load truck tire noise from the front area (wheel bearing, I think) Kinda strange as when I purchased the car 4 years ago they replaced the right side under warranty and now at 112k miles the other side is prolly gone! anyone else have a similar problem and is it expensive?
Old Jul 25, 2010 | 06:59 PM
StratagemII's Avatar
Yes
Had same problem on my 05x @ about same mileage/ Just make sure you order correct bearing ( different than RWD's ) check Riverside and any decent machine shop should be able to press it for you.
GL
Old Jul 26, 2010 | 10:01 PM
jayflyxx's Avatar
yah so this driver side bearing is only available at infiniti and now I have to wait because its $290 for the part! wtf?
Old Jul 27, 2010 | 01:37 AM
TurTLe*'s Avatar
ouch... yea i didn't see one for the AWD.
RWD fronts are with HUB is only $212 and its just a bolt-in type of thing. I found RWD bearings for the rear for $50. $290 for the front is rape.
Old Jul 27, 2010 | 06:51 AM
Wannabe6MT's Avatar
-MN G Crew-
What mileage do the bearings usually go out at?
Old Jul 27, 2010 | 09:38 AM
OKStateG35's Avatar
$185 shipped at Riverside Infiniti.
http://www.riversideinfiniti.com/j/i...bayOnline.html
Old Jul 27, 2010 | 10:06 AM
azt108's Avatar
If you can buy the bearing and hub pressed together already, you can DIY. Otherwise, buy the bearing and bring it to a shop. Cost me $130 for labor and I can't remember how much the part was, but I did buy it from the stealership.
chinee
Jun 10, 2024 07:48 PM
Th611
Oct 27, 2015 03:48 PM
Gip
Aug 24, 2015 05:31 PM
Phenomenon9
Aug 9, 2015 01:34 AM
