Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jul 30, 2010 | 02:58 PM
  #151
Tollboothwilley's Avatar
Originally Posted by Wannabe6MT
I honestly think its the handle pulling away from the actual panel and its rubbing. I dont know what else it could be. I have pulled that panel off 3 times now in search of what it could be. I am bad at getting rid of rattles and pops though...
Sounds like the rear window bolts. I need to get those too. Mine is rattling like a **** when i go in and out of the driveway. I roll the windows down a crack though, and they stop. Apparently that means its the window bolts.
I had issues with door rattles. I took of the door panel and found that a couple bolts had rattled loose - probably from the stereo. Locktite the bishes and the rattles went away.
Old Jul 30, 2010 | 03:35 PM
  #152
Originally Posted by NFSP G35
Ok, here's my RLQ.... is every G35 AC compressor noisy, or do I need to worry?
Most early 2003 Sedans have a slightly different AC compressor and they are noisy as hell. There was a TSB to change out under warranty a long time ago where they used a different compressor.
Old Jul 30, 2010 | 03:37 PM
  #153
Originally Posted by Gusc35
whenever i turn the steering wheel to the left there is a high pitched soft grinding/squealing noise coming from the front. it sounds like its coming from somewhere around the front drivers side wheel well. My rotors are warped i am not sure if thats whats causing the problem or not. any input would be appreciated
Check your Steering Rack & Pinion for leaks. Check fluid - could be dirty and most likely needs to be cleaned/flushed with new fluid.
Old Jul 30, 2010 | 04:56 PM
  #154
NjMatteSedan's Avatar
I guess I lucked out. Mine's quiet
Old Jul 30, 2010 | 05:19 PM
  #155
If you have an 03 then it may have been replaced already...and that would make you lucky. haha
Old Jul 30, 2010 | 05:26 PM
  #156
SN00P's Avatar
CLUB MODERATOR
new coils go on tuesday !!!!!!!!
Old Jul 30, 2010 | 11:40 PM
  #157
SN00P's Avatar
CLUB MODERATOR
i need some OP.... here is my current wheel set up and im looking for some extended lugs nuts ... what you guys think ,Neo Chrome , black, Red
Old Jul 30, 2010 | 11:47 PM
  #158
NFSP G35's Avatar
? = 2B || !2B
Hey John, is the AC compressor the same as the newer ones, or do you know?
Old Jul 31, 2010 | 04:39 AM
  #159
JBF's Avatar
JBF
is anyone on here a lady-boy?
Old Jul 31, 2010 | 08:22 AM
  #160
GeeGirl82's Avatar
Can I use my oem xm antenna with a dd unit?
Old Jul 31, 2010 | 09:44 AM
  #161
nazc0's Avatar
2006 Vortech supercharged Sedan
red would look a bit odd i think just silver would do but congrats on the new setup non the less
Old Jul 31, 2010 | 09:56 AM
  #162
SN00P's Avatar
CLUB MODERATOR
^^ i went with some black Kics :-) ... im picking them up today
Old Jul 31, 2010 | 11:29 AM
  #163
Not the same compressor but the newer ones are the same basic design. Should bolt right up if you replace it. Someday I'll replace mine and kill the weed-whacker LOL I turn off the AC when I'm accelerating from a stop so I don't have to listen to it.
Old Jul 31, 2010 | 12:23 PM
  #164
NFSP G35's Avatar
? = 2B || !2B
^Thanks.
Old Jul 31, 2010 | 12:48 PM
  #165
Wrathernaut's Avatar
Gentle Manne of Leisure
Doubtful.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
