Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #3931
Old 05-21-2011, 02:00 AM
MannyFresh's Avatar
On the 03 sedans are the turn signals suppose to be on when headlights are on?
  #3932
Old 05-21-2011, 02:13 AM
xxxxxxxxxx's Avatar
mine dont , but is an 04
  #3933
Old 05-21-2011, 02:24 AM
MannyFresh's Avatar
Well 03-04 are pretty much the same.
I was just curious cus I saw a coupe and they were on. So I figured that mines should be on too, but I guess not.
  #3934
Old 05-21-2011, 02:46 AM
xxxxxxxxxx's Avatar
yeah i think coupes are different
  #3935
Old 05-21-2011, 10:29 AM
G35Papa's Avatar
Originally Posted by xxxxxxxxxx
i need to get the one that goes here. i have the other one off , i should take that one right.
It's a special bolt. It has a build in washer and uses a special washer on the back end. Since you have camber kits, you can get away with using a different bolt but if you ever had to take it back to stock, you wouldn't be able to adjust camber on that side. That is what the bolt is used for, oem camber adjustment.
No. This feature was added starting in 05
  #3936
Old 05-21-2011, 10:37 AM
4DGS's Avatar
Looks like dissss
  #3937
Old 05-21-2011, 03:03 PM
thescreensavers's Avatar
Mr.202?
you can adjust camber stock? what?
  #3938
Old 05-21-2011, 04:46 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Only in the rear and there's not a whole lot of adjustment available.
  #3939
Old 05-21-2011, 06:31 PM
TheGThirty5's Avatar
Originally Posted by 4DGS
I wouldn't spend more than $150 on them with low miles.
Anymore and you might as while buy brand new Tokicos.
for the shocks and springs??
  #3940
Old 05-21-2011, 06:34 PM
Mr.202?
That I could understand but I never knew there was even "some" available ha.
  #3941
Old 05-21-2011, 08:57 PM
CG4DR's Avatar
Anyone got info on window curtains? Brand, size, general info on how to install??
  #3942
Old 05-21-2011, 09:57 PM
OCG35's Avatar
you should be a trend setter and do venetian blinds (retro like Karmann Ghia)... or even more hard-core; Plantation Shutters
Or Untra Hard-Core and mold the rear/side windows and doors solid with the body
  #3943
Old 05-22-2011, 01:51 PM
Hotdawwgman's Avatar
Lol Mike...
  #3944
Old 05-22-2011, 02:21 PM
Gotdirt100's Avatar
Im looking for a programmer for my '03 G35 sedan...I do have some engine mods including headers, intake, some port and polish work done with my plenum and throttle body and chipped through jet performance.. pushing well over 300 HP Now my question is when i buy a programmer how does that affect my ecu flash through jet performance? And what prgrammer is recommended???
  #3945
Old 05-22-2011, 02:42 PM
CG4DR's Avatar
you don't need to run both
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
