Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Oct 27, 2013 | 02:33 PM
  #9706
thegreatkwijibo's Avatar
Originally Posted by g35loving
Yes it would. Before I put spacers I am running 20x10 +25 offset and fit perfect with little to no rubbing
thanks man how bad did you have to molest your fenders?
Old Oct 27, 2013 | 07:48 PM
  #9707
silver9's Avatar
Hello everyone, my mechanic added a bit too much engine oil when I got my change yesterday. He put ~6 quarts in there. I feel like there's a loss in power. Any suggestions?
Old Oct 27, 2013 | 08:32 PM
  #9708
g35loving's Avatar
Please tell me you drained a qt out.
  #9709
g35loving's Avatar
Without spacers I did not have to mess with the fendwrs
Old Oct 27, 2013 | 08:34 PM
  #9710
Cool thanks man.
Old Oct 27, 2013 | 08:37 PM
  #9711
NFSP G35's Avatar
? = 2B || !2B
Put a mob hit on your mechanic?
Old Oct 27, 2013 | 09:39 PM
  #9712
silver9's Avatar
I don't understand his sudden incompetence. My car burns oil after ~1k. Is it necessary that I drain a quart as soon as I can?
Old Oct 27, 2013 | 11:14 PM
  #9713
^yes
Old Oct 28, 2013 | 12:26 PM
  #9714
dofu's Avatar
20 Year Member
If your crankshaft dips into the oil while it's turning, the weight of the oil will slow it down, and that is where you feel a loss of power. Imagine how damaging that can be to the motor - it's almost like reaching in there with something and jamming the moving parts. If you start hearing new sounds and its diagnosed that you need new bearings, you know why.
Old Oct 28, 2013 | 01:49 PM
  #9715
Also it'll start burning a whole bunch of oil and your cats won't like that at all
Old Oct 28, 2013 | 11:58 PM
  #9716
cdrinkh20's Avatar
Take it back to the mech who did this and make him suck it out with a tube in his mouth
Old Oct 29, 2013 | 04:08 PM
  #9717
weiizy81's Avatar
Noob question
So I was planning on getting a z tube, do I need to get a filter with it or not, most I've found don't come with filters. Also I was going to go with stillen, but saw you could use the 350z intake and swap it on..am I correct?
Old Oct 30, 2013 | 12:44 AM
  #9718
dofu's Avatar
20 Year Member
You will be fine swapping the g-tube for either an oem z-tube or the Stillen z-tube without changing the intake box or filter. There is a lot of info on this simple mod, it seems you need to just do a quick search and a little reading about it so you can understand what a z-tube really is.
Old Oct 30, 2013 | 04:30 AM
  #9719
Drew113's Avatar
Ban Hammer Expert
^^correct, many just do a simple z-tube swap and drop in filter for better results
Old Oct 31, 2013 | 05:28 PM
  #9720
G_DiRTY5's Avatar
Yea I was at that point once. I was gonna get the stillen z tube with stillen intake but then I read somewhere on this forum that the stillen z tube is low quality and pics were shown of the inside which had things sticking out and random holes which would cause turbulance of the air passing through the tube. I ended up going with the OEM z tube with stillen intake.
I'm sure you wouldn't notice that little tiny difference but it's something to keep in mind when buying and I'm picky.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
