'03/04 Sedan Owners - Cleaning Forged Rims...
Old Aug 5, 2010 | 02:13 PM
Matzo Ball's Avatar
Question '03/04 Sedan Owners - Cleaning Forged Rims...
For those w/ the OEM '03/04 brakes that produce alot of dust, what do you use to clean your wheels? My Nismos are getting dirty and I dont want to screw up the finish.
Old Aug 5, 2010 | 02:22 PM
VEEG35.0's Avatar
just go to a parts store and buy some ceramic pads i use autozone golden ceramic ultra pads and no dust what so ever i forgot what brake dust looks like cuz i have not seen it on my car
Old Aug 5, 2010 | 02:41 PM
Matzo Ball's Avatar
thanks...now how about cleaning?
I will be going w/ a front bbk just to avoid brake dust.
Old Aug 5, 2010 | 02:46 PM
Jeff92se's Avatar
Red Card Crew
I upgraded to the 2 piston fronts and bigger rotor rears to fix this problem
Old Aug 5, 2010 | 02:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
All brakes produce some dust foo.
Originally Posted by Detailed Image
Best (and safest) wheel cleaner I've used is the P21S Gel Wheel Cleaner. It's pH balanced so it's safe to use on any wheels surface, but it's cleaning power can be multiplied by letting the product sit on the surface for long periods of time (up to 2 hours). After you let the product dwell, you'll want to wipe the surface down with a sponge, mitt, or brush to agitate the brake dust. Rinse it off, and touch up any areas as needed.
Or check out this thread.
https://g35driver.com/forums/care-de...l-cleaner.html
I just wash my wheels with the ONR mix I wash the car with and dust isn't a problem. I wash once a week though so not a lot of time for dirt/dust to get bad or adhere to the wheels.
Old Aug 5, 2010 | 02:52 PM
azt108's Avatar
You should post in the detailing section FYI.
Cleaner:
http://www.armorall.com/products/vie...dex=wheel_tire
Protectant After:
http://www.armorall.com/products/vie...?product_id=33
Old Aug 5, 2010 | 02:55 PM
Matzo Ball's Avatar
My fronts are the major problem. How much are the 2 piston calipers up front. Direct swap for the '04 OEMs?
Yeah I know all brakes produce dust...just some less than others I wish I had time to wash my car every week
Old Aug 5, 2010 | 03:34 PM
VEEG35.0's Avatar
05-06 is a direct swap for the 03-04
Old Aug 5, 2010 | 03:40 PM
DaveB's Avatar
Wash off your rims every week My 03's brakes dust like a ***** onto my 18" mutli-spoke rims. A simple shot with the hose removes 95% of the dust without the need of a wheel cleaner.
Old Aug 5, 2010 | 03:45 PM
canucklehead's Avatar
wash wheels regularly. water, car shampoo, and a wash mitt. every ~1 week or so.
my 19" coupe rays are a pain to clean but it has to be done.
Old Aug 5, 2010 | 03:46 PM
VEEG35.0's Avatar
if ur thinking about goin with a bbk dont do the 05-06 swap no point u can just change the pads for future dust before you get the bbk and u wont have to worry about cleaning ur wheels at all maybe a light dusting of the wheel but if u get the full ceramic pads u shouldnt have any dust problems
Old Aug 5, 2010 | 03:59 PM
ray1370's Avatar
OEM 05/06 front brakes, rotors, pads should be around $200~$300 on Marketplace; IIRC the torque members are different, so if you're getting a set make sure they are included just to be safe.
Old Aug 5, 2010 | 04:24 PM
itgogitrev's Avatar
Here's what I do for cleaning....
1.) I wash my wheels with P21S cleaner, I let it soak in for about 2 minutes and wash them with a microfiber cloth. Brushes will scratch, no matter how "soft" they say they are.
2.) Every 2 months, I'll pop the wheels off, give the inner barrels a good cleaning, and use Wheel Wax on the inner barrel, outer lip, and face. It's really nice because a strong jet of water will be enough to remove about 90% of the brake dust.
I still have the standard 04 brakes and they dust like crazy. I'll be changing them out for something new when funds allow.
Old Aug 5, 2010 | 04:29 PM
VEEG35.0's Avatar
i have stock 04 brakes too but not dust at all i love it im telling u guys the ceramic pads do the trick
Old Aug 5, 2010 | 04:32 PM
Matzo Ball's Avatar
can I get a good wheel wax/cleaner at my local AutoZone, etc? Would like to give them a cleaning tonight.
